Thread: 4 Channel Amp Help!
Results 1 to 20 of 24
  1. #1 4 Channel Amp Help!
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    I just recently purchased new front and rear speakers for my car. The fronts are rated at 250RMS and the Rears at 300RMS. I want to buy a four channel amp because I feel as though the sound isn't "full" enough and I think it is because the speakers are being underpowered by my deck ( correct me if im wrong ).
    What I need to know is how many watts should I be looking for from a four channel amplifier. Also, Im pretty new to car audio, I have no idea how to go about hooking one up, I can run the power ground and remote wires no problem, I just have no Idea how to get the sound to the speakers, my deck has rca outputs on the back of it for speakers..would the amp just connect to those via rca cables? and then just run speaker wire from the amp to the speakers?
    Any help is appreciated!
  2. #2 Re: 4 Channel Amp Help!
    Sep 2011
    Arkansas
    Honestly, even 50 watts sounds very nice on interior speakers. You can look for as much power as you want to pay for. 150x4RMS might be a good place to look, although something that puts out 100x4 would be cheaper, and still sufficient.
    As far as connecting it... disconnect the stock speaker wires. Run the RCA cables from the rear of your headunit to the amplifier, then run the speaker wires from the amplifier outputs to the corresponding speaker. Blammo, you're done. You'll also have a lot more control over your system, depending on how robust of a crossover network your chosen amplifier has. What is your budget?
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  3. #3 Re: 4 Channel Amp Help!
    May 2011
    id like to stay under 200$ if possible, ill be looking for an amp on kijiji
  4. #4 Re: 4 Channel Amp Help!
    Sep 2011
    Arkansas
    Never used Kijiji, but here's a well-respected one from a site that I've used personally on more than a few occasions. Excellent customer service and fast shipping. MB Quart ONX4.125 - 1000W RMS ONYX 4-Channel Car Amplifier/Amp This is a very nice amplifier, and it won't break the bank. You should also be able to get quite loud while still having plenty of headroom (unused power potential) left.
  5. #5 Re: 4 Channel Amp Help!
    May 2011
    Quote Originally Posted by Fatboy501 View Post
    That does look like a good one, would 1000W be to powerful for my speakers? and do you think having an amp hooked up to speakers makes a big difference? I have heard from ppl that it does, but i have never listened to a system with speakers on an amp.
  6. #6 Re: 4 Channel Amp Help!
    Sep 2011
    Arkansas
    It makes a HUGE difference. I doubt that would be too much power for your speakers, but you don't have to get that one... if you look, they have some lower-powered 4 channels as well. Honestly, without a subwoofer to keep up with, I believe about 50-60 watts x4 rms would be more than enough. However, with the larger amp, you'd have the room to up the power when you begin to feel that it's too quiet.
  7. #7 Re: 4 Channel Amp Help!
    May 2011
    I have 2 10s running on 500W, so thats probably why i feel as tho the speakers arent loud enough, the bass is just too powerful sometimes.
  8. #8 Re: 4 Channel Amp Help!
    Sep 2011
    Arkansas
    Ah... yes, that tends to happen. 75 watts RMS will be more than adequate in my opinion. However, were I in your position, I'd go ahead and get the 125x4 because of the headroom, and the fact that you can simply run more power when you feel the need to without switching amplifiers.
  9. #9 Re: 4 Channel Amp Help!
    May 2011
    Ya I will most likely go with the 125x4, thats right in my price range and the reviews for that amp are all good. Thanks for the help, Ill report back once I get the amp ( will most likely order next week ) and hopefully you can help me with any install troubles i come across.
  10. #10 Re: 4 Channel Amp Help!
    Sep 2011
    Arkansas
    No problem... there are more members which may have some more suggestions as well.
  11. #11 Re: 4 Channel Amp Help!
    Fargo, ND
    I'm curious as to what speakers are 300 watts RMS? Or even 250 watts RMS? Are these speakers or subs?
  12. #12 Re: 4 Channel Amp Help!
    May 2011
    Quote Originally Posted by skeelo58 View Post
    I was wrong, here is the links for the speakers I have:
    Rears :Kenwood 6 x 9" 4-Way Car Speakers (KFC-6983PS) : 6"x9" Speakers - Future Shop
  13. #13 Re: 4 Channel Amp Help!
    May 2011
    Cant find my front speakers
  14. #14 Re: 4 Channel Amp Help!
    Sep 2011
    Arkansas
    Ah... yeah you can step on down to a lower-powered amp in that same line. You'll still be satisfied. It makes a night and day difference even with modest power.
  15. #15 Re: 4 Channel Amp Help!
    SE Level Member Bologna's Avatar
    Oct 2011
    Illinois
    I think you would be satisfied with a simple $50-$100 amp. One that does around 70rms to all four channels
  16. #16 Re: 4 Channel Amp Help!
    May 2011
    Quote Originally Posted by Bologna View Post
    I think that's what I might do, like i said, i just want a little louder and clearer.
  17. #17 Re: 4 Channel Amp Help!
    Oct 2011
    Illinois
    Quote Originally Posted by cameron92 View Post
    I just picked up a small 4 channel for $50 bucks and it came with 8ga power wire for it. It is rated at like 60 rms and it does fine. It's a huge improvement.
  18. #18 Re: 4 Channel Amp Help!
    Fargo, ND
    Those speakers look like they'll do the trick.
    All this talk about 4 channel amps is kinda making me think about getting one myself.... I don't know how well a 2 amp system in my car would work though since I already got a 1000 watt Class D.
  19. #19 Re: 4 Channel Amp Help!
    May 2011
  20. #20 Re: 4 Channel Amp Help!
    May 2011
    Also, I already have an 8 gauge wire running to my amp for my sub, could I just tap into that, or should I run another line from the battery?
  1. Noise with 4 channel amp.
    By WhiteGT in forum Audio, Security & Visual Electronics
    Last Post: 05-17-2009, 04:51 PM
  2. mono amp vs two channel
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2009, 12:04 PM
  3. any interest in setting up IRC channel?
    By fst in forum Forum Bugs/Suggestions
    Last Post: 12-13-2008, 02:56 PM
