Thread: Lights dim when my bass hits.
Page 3 of 3 FirstFirst 123
Results 41 to 54 of 54
  1. #1 Re: Lights dim when my bass hits.
    Feb 2009
    Virginia
    this is getting really complicated....
    op. Fix your poor grounding surface area. You want as much contact from the wire to the bolt and finally, to the ground surface as possible.
    11 is louder than 10!
  2. #2 Re: Lights dim when my bass hits.
    GT Level Member papaspanky's Avatar
    Jul 2010
    new england
    add an extra battery in the form of an extactic batt cap 800 cca's weighs about 7 pounds its agm so it can be mounted anywhere. I had 3200 watts in my taurus and ran one and the lights never dimmed.
    81 T/A pure Pontiac 350,700r4 3.23's coming soon pure Pontiac 462 06 gt wizaird,XS power Headers,zzp ss ic,overkill tune 180 stat autolite 104's, 3.6 pulley.Special Edition HORNY DRIVER mod.
  3. #3 Re: Lights dim when my bass hits.
    Pennsylvania
    Usually you won't have clipping unless your gain is maxed out. Also, I want to say my radio goes to 35, I've never capped it so idk, but I've never turned it past 22 so I'm never at full volume anyway.
    Also, the HU voltage and level/gain voltage is just a sensitivity level. So on my radio, 2V Pre-out sensitivity, and I set my amp to roughly 2V input sensitivity.
    Alright, lemme walk myself through this. You're turning your volume up to ~63%... a bit less than the typical ~75% you'd tune with a MM at. I actually used 24/32, or 75%, by sheer coincidence - it's as loud as my music could get before I heard distortion. So, you've got slightly more headroom on gain control before clipping than someone else might.
    I am assuming your gain is labeled 1V-4V or something like that, so that 2V is 12 o'clock? Mine's labelled "Min" and "Max". Might be why I've never bothered to think about trying to match this to my HU. If it was 1-4V like the examples in the link, I'd say my gain is set close to 2.5V (or halfway between 2V and 4V labels). But I've got no idea what my HU outputs. I'm guessing, then, that I could never match.
  4. #4 Re: Lights dim when my bass hits.
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by SlowNA06 View Post
    mine actually says 6 to .2 volts. i've got a bit more range, and it rotates like... 400-500* or so. kinda awkward, but i figured it out.
    Edit: Pichaaarr
    Visual help, that's what mine looks like
  5. #5 Re: Lights dim when my bass hits.
    Pennsylvania
    Edit: Pichaaarr
    I'm confused as to how you set input sensitivity to 2V. Like... how did you find 2V on your gain/level knob? But I did read your amp manual and that process is exactly what it says to do.
  6. #6 Re: Lights dim when my bass hits.
    Feb 2009
    Virginia
    Quote Originally Posted by papaspanky View Post
    Extra battery isn't an issue. His problem is that lights dims with a "200 watt" amp while the engine is running. He needs a better ground for the amplifier. As stated already....clipping could be an instigating factor too. But if lights are dimming with a small amp then it's a poor ground...unless his alternator is on it's way out, not likely.
  7. #7 Re: Lights dim when my bass hits.
    Feb 2009
    Virginia
    Music is dynamic...so unless you play a tone it's hard to realize the actual voltage read out. With that said...music can be recorded at different volumes; hence, some tracks clip and others don't. Also, there is some voltage drop depending on RCA cable length. That's why line drivers are used in some applications. It also makes it easier to set, forget, and swap equipment as needed.
  8. #8 Re: Lights dim when my bass hits.
    Nov 2008
    Waterloo, Iowa
    I turned it all the way one way, and all the way the other to figure out how many degrees the knob could be turned, one full rotation and one half rotation = 540*. Then I did a little math. The min is 6v; 0*, the max is .2v; 540*. Halfway between those two settings would be (6+.2)/2 = 3.1v; 270*.
    So now I know halfway, I know the needed value is between half max and max, and if I find out 3/4 max, I can get a pretty good guess on where to put it.
    3/4 would be (.2+3.1)/2 = 1.65; 405*.
    So now I know I have to turn it roughly halfway between half and 3/4 max, so roughly 335*, a bit less than one full rotation.
    Does that make sense?
  9. #9 Re: Lights dim when my bass hits.
    Pennsylvania
    If the values are linear (which from what I've seen from a handful of amps, they seldom are), yes.
  10. #10 Re: Lights dim when my bass hits.
    Feb 2009
    Virginia
    Potentiometers are a manufactured part and subject to quality issues too :/
  11. #11 Re: Lights dim when my bass hits.
    Nov 2008
    Waterloo, Iowa
    Leastwise I have it set to something. If I had the tools to measure it out, I'd simply do that... until then, it's better than having it maxed out.
  12. #12 Re: Lights dim when my bass hits.
    Pennsylvania
    True. For something like $6-$20 you could pick up a digital multimeter that would do you fine.
  13. #13 Re: Lights dim when my bass hits.
    SE Level Member Bologna's Avatar
    Oct 2011
    Illinois
    Exactly. Takes from 1 minute to 2 minutes.
  1. Light pulse when amp hits
    By BeastGT in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2011, 11:58 AM
  2. E85 Turbo'd GP hits the dyno!!
    By glanzergtx in forum General Tech Discussion
    Last Post: 08-07-2010, 06:38 PM
  3. 1997 gtp sometimes only hits 4k rpm
    By KOOLJAYONE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2010, 02:05 PM
  4. Best Bass CD
    By Freebeer187 in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2009, 04:44 AM
