Thread: Battery advice
Results 1 to 9 of 9
  1. #1 Re: Battery advice
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by ajoliver2010 View Post
    You're not being a dick at all lol. I just figured a battery upgrade would be the right choice. Right now i have a Duralast red top battery, but its just a pair of post terminals so i have my car audio wires coming from the positive part on top of the fuse box. Im not sure if thats safe or not but i havent had any problems so far : /
    Well Its not the best way of doing it. I would look into a battery terminal that supports not only your cars electrical system on the positive terminal but also accepts whatever gauge wiring you use for your audio system (8guage, 4guage, ext) Thats the best way of doing it in my opinion, or a terminal extension for a side mount battery that features a simple bolt to screw on ring terminals (this is what I'm rocking) looks great, works great, simple to use. Made by stinger if your interested, maybe 25 bucks. And I understand that battery upgrade thing, makes sense right, more subwoofer= more battery right? Your car will be just find with your red top, thats a great battery. I have a yellow top dual cycle, so I get both cold cranking amps and some aspects of a deep cycle battery (able to be discharged without killing the battery). Anyways, the only real way to upgrade your electrical system to support systems really greater than ~1K watts is an alternator upgrade and battery grounding wire upgrade. The alternator is very expensive (200+) and the batteries grounding is well unnecessary if you stay under the ~1K watt threshold. So if your under that, upgrade your battery post/terminal to accept your positive wire to your amplifier and enjoy!
    Infinity all around.
  2. #2 Re: Battery advice
    Jersey
    Quote Originally Posted by chamilton89 View Post
    The terminal extension sounds interesting. Can you take a pic of it so i can get an idea??
  1. new battery? maybe?
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 11:48 PM
  2. Where should I get my battery
    By LowRidinCrew in forum General Tech Discussion
    Last Post: 01-25-2011, 01:05 PM
  3. Getting a car battery
    By Warbeaver in forum General Tech Discussion
    Last Post: 05-31-2010, 06:11 AM
  4. Battery
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2009, 11:21 AM
  5. okay, I took the battery out of my '96 GP
    By karkev in forum General Tech Discussion
    Last Post: 06-17-2009, 09:21 PM
