Thread: Another HID Fogs question (installation)
Results 1 to 12 of 12
  1. #1 Another HID Fogs question (installation)
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Hello I bought the 3000k 35w hids for my fogs and I just put them in. When i checked the first one it worked fine after installing the 2nd one the fuse blew. it has a 10 fuse, Should i just buy another 10 fuse and put it in or do you think i need a bigger fuse? It said on the web site to buy that harness but that was if you were running multiple hids on an ATV or small type of vehicle like that. I do also have 6000k for my driving lights. Thanks
  2. #2 Re: Another HID Fogs question (installation)
    St. Cloud, MN
    Just get another fuse. If it keeps blowing it the ballast is probably bad.
  3. #3 Re: Another HID Fogs question (installation)
    Nov 2010
    Damn ok, Thanks. And i bought 3000k fogs and 6000k high beams (i have projectors) at the same time. no label on the 4 ballasts. would that matter?
  4. #4 Re: Another HID Fogs question (installation)
    St. Cloud, MN
    I don't really understand your question?
  5. #5 Re: Another HID Fogs question (installation)
    Nov 2010
    could i have mixed up the ballasts?
  6. #6 Re: Another HID Fogs question (installation)
    St. Cloud, MN
    I doubt it.
  7. #7 Re: Another HID Fogs question (installation)
    Nov 2010
    ok thanks
  8. #8 Re: Another HID Fogs question (installation)
    Top Swap in Progress bigtom9492's Avatar
    Dutchess county
    if they are the same wattage then the ballasts don't matter if they are mixed up.
  9. #9 Re: Another HID Fogs question (installation)
    Nov 2010
    alright thanks, I actually got a 20 fuse to replace the 10 fuse and they work just find now
  10. #10 Re: Another HID Fogs question (installation)
    Sep 2011
    MI
    Never a good thing to put a larger fuse in. A 10A fuse means thats what the circuit is rated for. Instead of the fuse popping as it is designed to do the wire could melt causing big issues. a buddy of mine head to rewire a 2000something dodge because they just put a bigger fues in. Buy a relay and wire them that way. I think the site the12volt.com has all the info for wiring relays and such...
    Edit: that site has the info, if ya need any more specific info lemme know!
  11. #11 Re: Another HID Fogs question (installation)
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    ^what he said unless you know how big gauge wire the relay harness is DO NOT PUT A BIGGER FUSE IN!
  12. #12 Re: Another HID Fogs question (installation)
    Nov 2010
    Thanks for the heads up
  1. Please help! Question about 6x9 installation!
    By Deebo in forum Audio, Security & Visual Electronics
    Last Post: 08-02-2010, 09:21 PM
  2. Question about air intake installation
    By GothTP in forum General Tech Discussion
    Last Post: 05-13-2010, 08:37 AM
  3. Water Pump Installation Question
    By Lawngoose in forum General Tech Discussion
    Last Post: 12-07-2009, 09:52 PM
  4. deck installation question??
    By reallyfast1 in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 07:40 AM
  5. hid fogs
    By rojo grandprix in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2009, 07:57 AM
