Thread: Wiring for rear deck speaker replacement (with Monsoon)
Results 1 to 8 of 8
  1. #1 Wiring for rear deck speaker replacement (with Monsoon)
    SE Level Member Infinity9999's Avatar
    Dec 2008
    Brookfield, WI
    I'd like to replace my 6x9s in the back of my 2004 with the Monsoon system. I haven't yet had time to pull it all apart to see for myself, but from what I've read, I have split wiring in the back to feed the bass on one pair and the mid/hi on a second pair. If I replace with a single 3-way 6x9, I'm supposed to do something to the wiring so that I can get all ranges to come through that one connection. I haven't been able to find how to do that, though. Is it just a matter of splicing the two pairs together before the speaker harness? I'm an audio/wiring noob, so an explanation/example would be awesome.
    04 Black GTP Comp G
    Mods: 3.2 pulley, SSIC, Wizair, AL104s, OBX headers, VS cam, 105# springs, 42# injectors, PowrTuner
  2. #2 Re: Wiring for rear deck speaker replacement (with Monsoon)
    Dec 2012
    Knoxville, TN
    This is a really old thread but uhhh... I'm going through the same crap. What did you you do?
  3. #3 Re: Wiring for rear deck speaker replacement (with Monsoon)
    Sep 2011
    Arkansas
    I replied in another thread here.... cliffs: Keep it simple... 6x9 midwoofer.... tweets... profit. There may be another solution, but I'm not aware of it.
    1978 F250 2wd (460 c.i.d. / C6)- soon to give up the powerplant to an '80-'86 F150
    White 2000 Grand Prix GT coupe
    One still slow and loud... other one scoots just a bit.
  4. #4 Re: Wiring for rear deck speaker replacement (with Monsoon)
    Dec 2008
    Brookfield, WI
    I actually ended up doing what someone else suggested and that was to get a new amp to run my 6x9s and 6.5s and left the Monsoon to run the center dash speaker.
    04 Black GTP Comp G
  5. #5 Re: Wiring for rear deck speaker replacement (with Monsoon)
    Dec 2012
    Knoxville, TN
    I installed Infinity Reference all around and connected the only the low pass to the rear. I want to re-connect the 3", 2ohm speakers to the high pass and use the factory bracket. Does anyone know where I can get only these or aftermarket? Does anyone have two they want to sell?
  6. #6 Re: Wiring for rear deck speaker replacement (with Monsoon)
    Dec 2012
    Cheyenne
    I am also wanting to replace my 2004 6x9's. I will post my assumptions and hope someone with a correct technical answer will reply... I want to replace the factory 2-ways with Kicker 3-ways. Since the monsoon amp splits the signal, couldn't I just splice them together and connect it to the normal input leads on the new speakers? Also, does anyone know if the signal is split because the amp separates frequencies or is it is split to send more wattage to the woofer and less the the mid/tweeter? I would be suprised if the amp also acts as a crossover and splits the freq's..
  7. #7 Re: Wiring for rear deck speaker replacement (with Monsoon)
    GTP Level Member simbah's Avatar
    Lala land
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  8. #8 Re: Wiring for rear deck speaker replacement (with Monsoon)
    Dec 2012
    Knoxville, TN
    I paid big $’s for the Monsoon upgrade in my ’06 Grand PrixGXP. It was a huge mistake! As I kept blowing speakers all around, I decided toupgrade all the speakers with aftermarket but it was a challenge to find 2 ohmand 3 ohm speakers that would fit. Finally, I did it! I’m a true audiophile andthe sound is HUGE.
    The solution is simple. I used Infinity Reference all around;in the dash, the doors, and even in the rear deck. I bought two 9602ix 6”x9”,two 6502ix 6 ½”, three 3002cfx 3 1/2”, and two 075tx 3/4” tweeters. I shopped,bought online, and paid less than $375 for everything.
    Everything fit and I kept all the factory harnesses intact.I simply clipped the leads from the crappy paper speakers and connected them directlyto the Infinity’s.
    The only challenge was the rear deck but it turned out to befairly simple. I took my Dremel and cut the enclosure part off the X bracketthat held the 3” crappy mid woofers and mounted the Infinity 3002cfx directly tothe arms of the modified X bracket. I had plenty of clearance, since I didn’tmount the 6”x9”s to the plastic, snap-in, speaker bracket like the stock ones.Instead, I literally just dropped the 6”x9” speakers right into the cutout inthe back deck. Then I snapped the factory speaker bracket on top of thespeaker, making a super tight mount without any fasteners. I connected the lowpass to the 9602ix’s and the high pass to the 3002cfx’s.
    Done! I know I lost a lot of the frequency response from allof the speakers because of the Monsoon amp/crossover but it was relativelyinexpensive and an easy installation. The sound I have is nearly competition. Ihope this helps everyone trying to do the same.
    Also, If anyone wants to purchase the factory speakers Ipulled out, hit me up in a private message. I have them all except the 3” midwoofers that were blown.
  1. Remove rear speaker grill, not the whole deck
    By BeastGT in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2011, 03:41 PM
  2. Rear Deck Speaker Installation
    By garreTT in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2011, 12:43 PM
  3. Rear Deck Speaker Grilles
    By SlowNA06 in forum Audio, Security & Visual Electronics
    Last Post: 05-25-2010, 12:18 PM
  4. New Rear Deck Speaker Grilles Needed For 2002 Grand Prix GT
    By LoveMyGPGT in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2010, 02:32 PM
  5. Monsoon Amp Remote Wire and Speaker wiring diagram
    By Thatonepunkrawk in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2009, 07:58 PM
