Thread: Accessory panel
Results 1 to 7 of 7
Logan541 Accessory panel 11-25-2011, 09:31 PM
ZaphoidB Re: Accessory panel 11-29-2011, 04:54 AM
Logan541 Re: Accessory panel 11-29-2011, 12:55 PM
dpzelenak Re: Accessory panel 11-29-2011, 10:50 AM
Logan541 Re: Accessory panel 11-29-2011, 12:58 PM
dpzelenak Re: Accessory panel 11-29-2011, 01:35 PM
Logan541 Re: Accessory panel 11-29-2011, 02:31 PM
  1. #1 Accessory panel
    Feb 2010
    TN
    I want to make a distribution block for some of my accessories that would only power on when the car is on can someone tell me where under the hood or in the interior I can tap into. a pic would be really nice. I don't to just piggy back off of a fuse.
    Thanks
  2. #2 Re: Accessory panel
    Nov 2011
    PHX
    There is a dedicated power drop that is behind the glove box. It has a 12v constant, 12v acc switched and ground. I don't recall what the power rating is, but if you require more power, then you can simply use the switched acc wire to power a relay for the power block.
    The power drop is designed specifically for aftermarket use. It is not connected to anything from the factory and is marked as such with a sticker on it.
    For heavier duty wiring, one of the main entry points for wires into the cabin is under the carpet on the passenger side, near the center console. You can easily put a primary wire through the boot for additional power inside.
  3. #3 Re: Accessory panel
    Feb 2010
    TN
    Quote Originally Posted by ZaphoidB View Post
    Thanks I just want to hook up some leds and a CB radio and 4 usb ports for charging cell phones and bluetooths I am guessing that the power drop behind the glove box should be good enough no?
  4. #4 Re: Accessory panel
    i ran another fuse block into the cab under the arm rest and its coming from the top stud off the fuse block thats in the engine compartment
    SMGPFC Member #10
  5. #5 Re: Accessory panel
    Feb 2010
    TN
    And this only has power when the car is started or in acc? You mean the thing that has the red cap covering it on the fuse block? Because I have one coming off there and that has constant power, or am I looking at the wrong thing?
  6. #6 Re: Accessory panel
    no it has power all the time,
    i ran toggle switches to control what has power and when
    SMGPFC Member #10
  7. #7 Re: Accessory panel
    Feb 2010
    TN
    toggle switches never thought of the the I can just power on what I want not a bad idea. Thanks
  1. switched accessory tap
    By ham4864 in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2010, 11:21 PM
  2. accessory belt
    By 98regalgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2010, 08:56 PM
  3. new Gun Accessory
    By RedGTX in forum Off Topic Discussion
    Last Post: 01-14-2010, 05:51 AM
  4. Accessory plug in
    By nrfitchett4 in forum Audio, Security & Visual Electronics
    Last Post: 04-14-2009, 06:15 AM
