Thread: Sub debate
Results 1 to 9 of 9
  1. #1 Sub debate
    Umatilla Oregon
    Currently I own one Kicker L7 10", but i'm debating between selling that and picking up a couple of JL W0's 10", are the cheaper JLs going to sound better than my L7? going for SQ not so much SPL, any thoughts?
  2. #2 Re: Sub debate
    Destroys cars izup69's Avatar
    Iowa
    Personalty I think JL has the best sound quality $ for $. You buy lower end speakers you get lower end/outdated equipment. I have 2 L7 12's sound great alot of how subs sounds not only has to do with what kind of sub but also what size/kind of enclosure you use. I have my box tuned for sq not spl and I think it sounds good considering. Plus ported boxes sound like **** b/c of the "lag" you hear from the air going in and out of ports. I dont think the JL's would sound worse. I just dont think they would hit as hard as the L7 got to remember the square design of the L7/L5 means a 10" sub moves as much air as a 12" sub. Id like to trade both of my L7's for a W7 but that ant gunna happen anytime soon lol
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  3. #3 Re: Sub debate
    Aug 2011
    oklahoma
    Quote Originally Posted by izup69 View Post
    ported boxes don't sound like ****. It depends in how their made and to what specs. If you hear port noise you need more port area.
  4. #4 Re: Sub debate
    Iowa
    Quote Originally Posted by traksta15 View Post
    lol you can only go so big with ports you have to take into account how big of a box your sub can handle and yes you hear airflow ask any installer. Its air flow in and out of the port which makes the sound "lag" and unless your going for spl u need a sealed box period. I know I have a ported box for my L7'S built to kicker specs for SPL and I have a box I built myself to kicker specs for SQ and my homemade box sounds better then the pro built ported. If u don't think ported boxes sound like **** for SQ then you need to turn your subs down and your hearing aids up.
  5. #5 Re: Sub debate
    Feb 2009
    Virginia
    Not really. "SQ" is based on a pre-determined frequency response that an INDIVIDUAL prefers and then finding a way to install and manage your car audio components to match that curve.
    Any sub can sound however you prefer in pretty much any enclosure you design. Aperiodic is a hybrid idea for ported/sealed and considered(by those who have listened) to be one of the better enclosures to use. However, good luck trying to master that.
    Bottom line...there's a lot of guess work in car audio but your goals can be realized if some deep thought, research, and good fabrication are used in your installation.
    11 is louder than 10!
  6. #6 Re: Sub debate
    SE Level Member vondoom88's Avatar
    Jun 2010
    Nowhere,IL
    I think he is referring to the higher group delay that is inherent to all ported boxes. Poor transient response vs. a sealed design. Not to say that all ported designs sound bad. If you listen to mostly rap you'd probably never notice the delay.
  7. #7 Re: Sub debate
    Feb 2009
    Virginia
    Quote Originally Posted by vondoom88 View Post
    Ported is tougher to get right but as a whole, this guy has it right. I think ported adds more variables than I care to deal with so I just use sealed
  8. #8 Re: Sub debate
    Iowa
    I have heard Alpines out perform JLs, same size, both good boxes, both tuned properly
  9. #9 Re: Sub debate
    GTP Level Member
    Nov 2011
    Kansas
    I have two older 10w0's... and in the trunk of my 08 GP, they hit hard, but also have a very nice bass sound with any music.
  1. Heated debate i had
    By klj5022 in forum The Rant Forum
    Last Post: 02-17-2011, 03:44 PM
  2. Another open cone vs sealed box debate
    By cleangtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2010, 05:01 PM
  3. supercharger or turbo debate
    By 98bullit in forum Introductions/Noob Questions
    Last Post: 11-30-2009, 12:51 PM
