Thread: Pink foam for a speaker box?
Results 1 to 2 of 2
  1. #1 Pink foam for a speaker box?
    Sep 2011
    MI
    Usualy I would use plywood/particle board and wrap it in carpet...blah blah blah... My question is would it sound like crap if I used the pink/blue insulation board then wrapped it in a thin layer of fiberglass? It would save a LOT in weight. I would of course use a wood ring to screw the speaker too.. Would the foam be not dense enough to make a quality sound?
  2. #2 Re: Pink foam for a speaker box?
    Feb 2009
    Virginia
    Hrmm. You're right in that the box determines sound. But I highly doubt the foam is doing much. There's an equation that represents the type of foam vs. thickness and it helps calculate to what frequency the foam is able to absorb frequencies. The truth is that there really isn't anything large enough for the wave lengths in the sub bass region.
    So why do people add foam n' such? A couple of reasons...help remove resonance(ringing), mimick air space when not enough is available, and to help with second and third order harmonic distortion.
    So now back to your question, is it dense enough to make quality sound? Well if you were using the foam as a skeleton for the fiberglass the real question is if your fiberglass is thick enough?
    Fiberglass Thickness Layers for Car Audio
    So your foam isn't an issue Hope that helps!
    11 is louder than 10!
  1. Pink Brake Light?
    By joeringo11 in forum 04+ Specifics
    Last Post: 06-25-2012, 10:30 AM
  2. Hot Pink Paint Job ?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 06-17-2010, 04:26 AM
  3. pink/purple turn signal bulbs
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 03-13-2010, 12:43 AM
  4. Sea Foam Question
    By slednut in forum General Tech Discussion
    Last Post: 10-31-2009, 09:45 AM
  5. calling any pink flammed GPs
    By SlowM90 in forum Off Topic Discussion
    Last Post: 07-30-2009, 11:23 PM
