Thread: best HIDs?
Results 1 to 20 of 25
  1. #1 best HIDs?
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Hello Im wondering what are a good set of HIDs that are fairly cheap. I had a set that came with my Spyder Halo Projectors and one is brighter than the other. Im looking for reliable HID bulb replacement so they are both bright. And Im thinking about 6000k HIDs for the fogs to match my headlights or should I get the 3000k? Does it help alot better in fog? Thanks
  2. #2 Re: best HIDs?
    Becca Boo MizzBecca's Avatar
    Michigan
    vvme
    and get the same fogs.
    I drive a POS
  3. #3 Re: best HIDs?
    retrofits that use a true HID bulb. anything else the quality is hit or miss and they dont perform worth ****.
  4. #4 Re: best HIDs?
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    I absolutely love my DDM Tuning HID bulbs and ballast's. Got both HID fogs and headlights. Easy to install, true to color temperature and output. Amazing price, and honestly super good quality from what I can tell. I accidentally placed one of my headlight ballasts in a section of the wheel well where a ton of water could kick up in it. Figured this out and removed the ballast and unscrewed the top cover, the entire thing was filled with water, but since the electronics were covered with plastic, nothing shorted or rusted and the thing still works today. Couldn't be happier.
    Infinity all around.
  5. #5 Re: best HIDs?
    Nov 2010
    Quote Originally Posted by chamilton89 View Post
    Do you need the HID Harness (Dual In/Out), The Error Eliminator, or the Adaptor Cables? Thanks these are cheap if you don't need any of these things lol. Did you have any errors come up or need and adaptor for the fogs? Thanks again
  6. #6 Re: best HIDs?
    Quote Originally Posted by Points70 View Post
    I bought the power harness for my headlamps and didn't buy them 4 my fogs. Both seem to work just fine although I would air on the side of caution and say get them. I believe they are only $15 more and I think you should have a solid 13.5v going to your ballast's and not have to worries about burning up the wires on the standard harness. NO need for the error eliminator.PLEASE READ THIS PART!!! A lot of people on this forum hates the high/low functionality of certain HID bulbs. I bought the headlamp bulbs with the high/low functionality and am glad I did. It isn't the best output on high beam but it DOES MAKE A DIFFERENCE and out in the country, I'm glad I had it. Also, on the color temperature, i have 6k for both fogs and headlamps. Solid White. Just the way I wanted it. Let me know if you have any more questions about DDM, the bulbs, or the installation!
  7. #7 Re: best HIDs?
    Nov 2010
    I have a set of the Halo Projectors from spyder. They have two different bulbs for the low beam(Projector) and the hid beam(Regular). But I really need to get HIDs for the high beams because they suck. Thanks for all your help. And I will indeed ask if I have any trouble with installation. Thanks!
  8. #8 Re: best HIDs?
    SE Level Member trewyn15's Avatar
    Nov 2011
    Janesville, WI
    I have DDM Tuning, I only needed the HID Kit, no extras, that's for low beams and fogs
    10000k lows and 8000k fogs
    2004 Monte Carlo LS
    Check it out here : Youtube
  9. #9 Re: best HIDs?
    SWPA
    10000k is ridiculous and puts out less light output than 4300k.
  10. #10 Re: best HIDs?
    i disagree
    my 10k's are brighter then my 8k's
    SMGPFC Member #10
  11. #11 Re: best HIDs?
    SWPA
    i disagree
    You are wrong. Facts don't lie. 10000k has less output than 9000k which has less output than 8000k. The purest HID you can get is 4300k.
  12. #12 Re: best HIDs?
    Bunnell, FL
    but you should get 5000k as it has a twinge of blue
    4300k sucks only because of the glass. if the quality sucks the output looks yellow if it's good then you get blue-ish
    I'm a Sex Offender
  13. #13 Re: best HIDs?
    i already told you why that is true.
    light output exponentially decreases as the kelvin value increases. its simple math.
  14. #14 Re: best HIDs?
    My infinitely adjusting non-calibrated lumen meters say they're brighter though?
  15. #15 Re: best HIDs?
    Nov 2011
    Janesville, WI
    I never said they put out the most light o_O
    2004 Monte Carlo LS
  16. #16 Re: best HIDs?
    Jul 2010
    Houston, Texas, United States
    I'm using 6000k in both heads and fogs, I love them. Just a hint of blue and bright as hell.
  17. #17 Re: best HIDs?
    Kansas
  18. #18 Re: best HIDs?
    How is 4300K yellow when all you see from everyone else is 3000-3500 K?
    I had 4300's and they were pretty blue to me.
    But no more blue than all of the other factory HID's I've seen.
  19. #19 Re: best HIDs?
    A lot of HID manufactures use a fairly arbirtary "color temperature" numbers, thus why there is disagreement on the viewable colors given at each color temperature. Color temperature is measured in (K) or Kelvin and is biased on an actual temperature of a black body radiator which radiates light at a specific hue, this hue, is the "color temperature" of a light source. Because the color temperature of 5500k correlates to the sun and the widest color band frequencies (a scale on which all spectrums of visible light are graphed), it is safe to say that the bulbs that most closely mimics that of the sun, is the brightest and easiest for our eyes to see since the band is fairly smooth without any harsh peaks. Somewhere between a warmer 5000k to a bit cooler 6000k is the "brightest" bulb although technically higher frequencies or warmer colors (red) are scientifically brighter. Therefore, although we may argue on which color temperature is "best", science says that the accurate color temperature of somewhere between 5000k and 6000k is your best bet albeit not the brightest.
  20. #20 Re: best HIDs?
    Nov 2010
    Hey everyone again. I have 2 more questions. I have the spyder halo lights and i want to buy a set of hids for the high beams. Are they 9007 like the normal stock bulbs? And when i get a set should i get the High and Low beam ones just in case i switch back to my regular headlights for any reason? Or can i only get the single because the high beam bulb isnt on unless you hit the high beams. Thanks
  1. My HIDs
    By SliceTheRice in forum Visual/Body Modifications
    Last Post: 01-09-2012, 06:02 PM
  2. HIDS
    By Lougp05 in forum Visual/Body Modifications
    Last Post: 02-10-2011, 08:23 AM
  3. Those who have HIDS
    By trenaro in forum Visual/Body Modifications
    Last Post: 12-05-2010, 06:51 PM
  4. HIDs on a 05'
    By tayl5645 in forum Visual/Body Modifications
    Last Post: 07-22-2010, 07:34 PM
