I agree with this. I will emphasize this in the tutorial.
Absolutely. There is no better tool for this than an o-scope, let alone a mere multimeter.
Here's where I thought I had done this correctly. I wired my sub so that the amp would operate at 1 Ohm, which my amp's manual says will result in 1000W. If I have done this wrong, please help me to correct it.
Again, I wish I had an o-scope to check this.
Bass boost is maxed when setting gain, so that no matter how high the bass boost is, it should avoid clipping. It is not to be left at max. I use the slightest touch of bass boost, perhaps a 5* turn of the knob. Without it, my sub sounds like farts on a pillow.
I will look into this.
This especially interests me. I suspect that this event manifests in a couple of tracks I have listened to, however very seldom.
I suppose I will have to find some. Everything I read on this was incredibly vague, which is part of my motivation for this tutorial.
Thank you for your input, it has given me much to consider. I am sadly the most experienced tuner among my friends now (they all, as well as local shops "tune by ear," which I have found to be consistently horrific/painful as well as destructive), so I need to rely on the advice of guys like you to learn more. Please be as free as you like with your advice here - I am far more student than teacher.
