Thread: Looking for a decent sub
Results 1 to 20 of 67
  1. #1 Re: Looking for a decent sub
    Aug 2011
    North Jersey
    Quote Originally Posted by I800C0LLECT View Post
    I don't. Proper grounding is what you need to get the most out of your alternator. We don't have anaemic wiring like our import counterparts. That means maximizing the contact between the wire and mounting point. You can start by soldering the wire and lead together...and I mean you get a torch out, blast the hell out of the lead and make a solder soup inside it before placing the cable inside.
    I will agree that the grounding point below the battery is pretty weak.
    does the big 3 not include 2 upgraded grounds? I did the big 3 with no other changes and headlight dimming went away along with "quicker starts". But like you said, proper grounding is what is needed
  2. #2 Re: Looking for a decent sub
    Feb 2009
    Virginia
    Quote Originally Posted by banks8604 View Post
    Well from my understanding MOST people follow through with the big 3 under the impression that it helps their alternator become a bit more efficient. The truth for our vehicles is what we've stated above. Grounds are a) poorly installed or b) corroded and need some lovin'. Therefore, you don't need a big "3". You need to do a Big Ground
    11 is louder than 10!
  1. Any decent 4th gen. F-body forums?
    By FordMan77 in forum Off Topic Discussion
    Last Post: 06-19-2011, 09:37 AM
  2. think these look decent
    By imdaman3 in forum Off Topic Discussion
    Last Post: 02-28-2010, 10:31 PM
  3. Can I find a decent gtp for 6-7 thousand dollars
    By Enjoijoe in forum General Tech Discussion
    Last Post: 08-14-2009, 11:18 PM
  4. decent deal on ws6 hood.
    By boosting98 in forum Off Topic Discussion
    Last Post: 09-30-2008, 12:20 AM
