I had to wire the switched power source to my gauges, because from what I've found, none of my fuses are switched. This requires manually starting the radio when I get in and turning it off when I get out.
You have two pink wires in your ignition harness, under the driverside dash. Why not just tag that line and run that to your gauges/radio?
