Thread: Someone Help This Noob Pick an Amp and a Box
Results 1 to 8 of 8
  1. #1 Someone Help This Noob Pick an Amp and a Box
    Nov 2008
    Waterloo, Iowa
    So I've ordered two of these little guys:
    Amazon.com: Kicker 10C124 Comp 12-Inch Subwoofer 4 SVC (Black): Electronics
    Now, after looking up the specs for these, I'm having trouble finding a good amplifier and box to put them in.
    I'm really after a ported box, no questions asked, but I can't seem to find one with a high enough internal volume to match these subs.
    As for power, I'm really awful at figuring this stuff out, but I was trying to find a 400-watt mono amp or something close, because I think I need to put 150-200 @ 4 ohm per?
    Basically... I needz halp.
  2. #2 Re: Someone Help This Noob Pick an Amp and a Box
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    well if you wire the subs together you will get a 2ohm load at the amp, so 500W @2ohm should be fine if you keep it clean, as far as box custom with propor tuning will always sound better than any prefab but also sealed is not a bad route you can always add pollyfill to give a deeper responce
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  3. #3 Re: Someone Help This Noob Pick an Amp and a Box
    Nov 2008
    Waterloo, Iowa
    So a mono amp with 500w @ 2ohm?
    Also, I think I'm going to buy a box, and then in the future build one.
    As far as wiring the subs together, is it like wiring anything else in a series? One wire from one sub positive to one sub negative and then the other terminals to their same sign on the amp?
    So:
    AMP[+][+]SUB[-][+]SUB[-][-]AMP
  4. #4 Re: Someone Help This Noob Pick an Amp and a Box
    Houston
    You will need to wire them in parallel, not series. +of one sub to + of the other. then - to - on the other then + to - on the amp
  5. #5 Re: Someone Help This Noob Pick an Amp and a Box
    Its okay to go too small.
    Worst thing that will happen is the peak will be too high, and not as significant.
    Means your sub will be safer.
    On wiring.
    Both sub positive to the same amp positive terminal.
    And both sub negatives to the same amp negative.
  6. #6 Re: Someone Help This Noob Pick an Amp and a Box
    Nov 2008
    Waterloo, Iowa
    Oh okay, I just assumed since he said together that he meant in a series.
  7. #7 Re: Someone Help This Noob Pick an Amp and a Box
    Cedar Rapids, IA
  8. #8 Re: Someone Help This Noob Pick an Amp and a Box
    Nov 2008
    Waterloo, Iowa
    I like pictures, they help. xP
  1. Help Me Pick!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 07-19-2011, 12:52 AM
  2. Help Me Pick a New DD GPF!
    By blueguy in forum Off Topic Discussion
    Last Post: 04-13-2011, 02:10 PM
  3. if you were to pick...
    By Bio248 in forum Off Topic Discussion
    Last Post: 01-19-2011, 05:02 PM
  4. I can Only pick one...
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-11-2009, 10:19 AM
  5. help me pick my new car!!
    Last Post: 08-31-2009, 10:27 PM
