Thread: Main reason for Amp to cut Out
Results 1 to 15 of 15
  1. #1 Main reason for Amp to cut Out
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    What do all of you think is the maon reason for the amp to cut out/Over heat after a while. I hear Grounding I hear Gain to high on amp
    WHat are somethings to do to prevent this
    I have to ground going to on eof the Shock Mount Screws and the gain on the amp is about 3/4
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: Main reason for Amp to cut Out
    SE Level Member Mr Book's Avatar
    Dunedin, FL
    Turn down the gain on the amp is one way, incorrect fuse, there are many different things that could be causing your issues.
    Since your gain is at 3/4 do you have to bass boost on or the sub level on your headunit jacked all the way up, also check the internal wiring of the amp to see if anything has come loose (do so at your amps peril if you don't know how to, cmoa)
    2000 Grand Prix SE - "One day all of this will be yours"
  3. #3 Re: Main reason for Amp to cut Out
    Jan 1970
    Maquoketa, Iowa
    Are you runnning the correct guage of wire? What type of amp/sub/wire combo do you run? It could just be a crappy amp or your doing something wrong in the setup.
  4. #4 Re: Main reason for Amp to cut Out
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Sounds like your running to low of an impediance. Like running an amp at 2ohm mono when it will only run @ 4ohm.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  5. #5 Re: Main reason for Amp to cut Out
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Quote Originally Posted by JCG's-GTP View Post
    I agree, how are the subs wired to the amp exactly?
  6. #6 Re: Main reason for Amp to cut Out
    Naugatuck CT
    THe amp has a selector for 2ch or 4ch right now I have the 2ch selected and the subs are connected Bridged 1 is on ch1 and 2 and the other to channel 3 and 4. I want get a new amp and have that amp run the 4 speakers in the back. Would a CAP Help
  7. #7 Re: Main reason for Amp to cut Out
    Las Cruces, NM
    No, how are the wires hooked to the terminals of the subs and where exactly does eash go, like positive and negitive sides of the amp.
  8. #8 Re: Main reason for Amp to cut Out
    Naugatuck CT
    Positive of sub number 1 goes to ch1 Positive on amp and Negitive of sub number 1 goes to Negative of Ch2 on amp Positive of sub number 2 goes to Ch 3 Positive on amp and Negative of sub number 2 goes to Negative of CH 4 on amp that is how the amp says to hook it up and the RCA jacks go in to Ch1 and CH3. It takes a while for it to cut out at high volume but it does feel super hot when it does cut out
  9. #9 Re: Main reason for Amp to cut Out
    Feb 2008
    I had a similar problem a few months back. I know you said you've checked the ground, but check it again. My ground wire broke partially at the strut mount nut and was only allowing an intermittent strong ground. The rest of the time, it was only partially grounded. What gauge power and ground wires are you using? Also, where is the amp located? Is it smothered or is it out where it can breathe easily?
    Like Mr Book said, you may end up having to increase the sub output at the HU and turn the gain down to about half if nothing else is awry.
  10. #10 Re: Main reason for Amp to cut Out
    Las Cruces, NM
    Is it a typo that sub 2 is hooked up to two positive amp terminals?
  11. #11 Re: Main reason for Amp to cut Out
    Naugatuck CT
    yes it was a mis print and the Wire is 5GA from the Batt and then gets split to 2 9GA to feed the 2 amps The ground is about a 7GA I can not really see to good with the sub in. It is the largest wire size Install kit from walmart. I know walmart sucks but it had some good size wires the 2 amps I am running are an 800Watt DHD 4 Ch and 600Watt Kenwood 2 Ch
  12. #12 Re: Main reason for Amp to cut Out
    Feb 2008
    Nashville
    What are the subs. Single voice coils or Dual Voice Coils
  13. #13 Re: Main reason for Amp to cut Out
    Las Cruces, NM
    Ohms are important, thats where I'm trying to get with thie issue. I really need to know the ohms of each voice coil. But since there are only 2 wires to each sub I'm guessing only a single voice coil per sub.
  14. #14 Re: Main reason for Amp to cut Out
    Naugatuck CT
    I will get all the specs this weekend but is this cap with anything or no if not where is a good place to get one or do you not think that I need one
    $24.99, 1.0% Rewards, LEGACY LCA160SL 1.6 FARAD DIGITAL POWER CAPACITOR *NEW*, L1345208300414 at PhiMart.com
  15. #15 Re: Main reason for Amp to cut Out
    Las Cruces, NM
    A cap is a cap, there's no such thing as a bad one. I'm all for adding 1 but you won't fix this issue with one. THere is a heat/connection issue right now and that will only add 2 more connections. Lets get you fixed before you install it.
    The homework for you:
    Amp make and model = ?
    Sub amp and model = ?
  1. 3800 SII main cap removal
    By turbocharged406sbc in forum General Tech Discussion
    Last Post: 01-03-2009, 04:27 AM
