Thread: Main reason for Amp to cut Out
Results 1 to 15 of 15
  1. #1 Re: Main reason for Amp to cut Out
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    No, how are the wires hooked to the terminals of the subs and where exactly does eash go, like positive and negitive sides of the amp.
  2. #2 Re: Main reason for Amp to cut Out
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Positive of sub number 1 goes to ch1 Positive on amp and Negitive of sub number 1 goes to Negative of Ch2 on amp Positive of sub number 2 goes to Ch 3 Positive on amp and Negative of sub number 2 goes to Negative of CH 4 on amp that is how the amp says to hook it up and the RCA jacks go in to Ch1 and CH3. It takes a while for it to cut out at high volume but it does feel super hot when it does cut out
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  1. 3800 SII main cap removal
    By turbocharged406sbc in forum General Tech Discussion
    Last Post: 01-03-2009, 04:27 AM
