Thread: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
Results 1 to 17 of 17
  1. #1 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    I have the Bose package in my 01 GTP. The whole system sounds great when turned up. Only problem is the rear speakers arent nice like the front. It appears only the front speakers are Bose and the rear are some delcos or something.
    I would like recommendations to upgrade the rear speakers. I also have a 4 channel Alpine amplifier that I currently do not use. I noticed the car already uses one though. Could I use it for the rear speakers? Should I?
    What speakers should i throw in there? Any setups/upgrades you recommend?
    Thank you!
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  2. #2 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    Jul 2008
    sumter,south carolina
    i had memphis "power reference" in my old gt...they put out very good sound for the price and the alpine amp should be plenty of power to push them.
  3. #3 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    GrandPrix Junkie
    Saraland Alabama
    there are no bose speakers in your car, bose licensed the name to audiovox. Brand wise there are literally a million choices, if possible go and listen to a few things in stores (i prefer small stores so you hear what you are listening to, not the guy buying a home theater)
  4. #4 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    Bartlett, IL
    Quote Originally Posted by archemedes View Post
    ! AUDIOVOX! Man....
    No highs, no lows, it must be bose
    Ill look into the speakers. I would like to run a better amp to the speakers though. Do you think the stock amp in the trunk would give me enough play to easily hook up a diffrent amp? A alpine 4 channel to be exact
    How To: E-Brake Pwn
  5. #5 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    While your going shop to shop listening, take your own CD. That way you know what it sounds like to your taste. If the shop doesnt let you play your own then they don't want your business.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  6. #6 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    GrandPrix Junkie
    Saraland Alabama
    the stock amp uses speaker level connections, so if you hook up your aftermarket one to them, you will have noise, run some rca's it is easy
  7. #7 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    Jul 2008
    Des Moines
    Most amps have a speaker level input too. Either use that or use a LOC. An amp on some nice 6x9s in the rear deck will sound really good.
  8. #8 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    GrandPrix Junkie
    Saraland Alabama
    Quote Originally Posted by bcrosby51 View Post
    if you buy the cheap amps they have speaker level input, of the 5 amps I have sitting here at the house none have speaker level
  9. #9 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    Jul 2008
    Des Moines
    "MOST amps"
  10. #10 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    GrandPrix Junkie
    Saraland Alabama
    few amps really
  11. #11 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    Jul 2008
    Des Moines
    I should clarify. I install for Best Buy, so you know, most of the crap they sell has speaker level inputs. I think the Alpines even have them, not for sure though. I always sell LOCs, even if the amp has speaker level inputs.
  12. #12 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    Jul 2008
    denver
    hi there a i have the same bose packand i been lookong in it for bit a long bit and u can't put any thing new in with the bose package sucks right to get the sound u looking for you got trash all of it and start new!!
  13. #13 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    GrandPrix Junkie
    Saraland Alabama
    I hate loc's with a passion, all they do is introduce noise for the most part
  14. #14 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    Jul 2008
    Des Moines
    What do you use then? I guess since 99% of the amps we install are for subs, introduced noise is not much of a problem.
  15. #15 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    GrandPrix Junkie
    Saraland Alabama
    if possible I change the head unit, stock ones are noisy to start with, and break too easy, if not then I use a good loc (less than 5% of jobs I do get a loc) I am also one that believes if you have an amp for subs you want an amp for everything, head units never have enough power to balance things , plus crossovers are easier to setup then also
  16. #16 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    Feb 2008
    Nashville
    I'm staying out of this since I had problems with all of the above... Begining to dislike my GP....
  17. #17 Re: 01 GTP W/ Bose package. Looking to Upgrade. Plz help :)
    St. Louis Mo.
    I had the Bose setup in my GTX and the one thing I did that made a world of difference in the beginning was simply swapping out the stock HU with only bass and treb for another stock unit that had the 5 band EQ in it. That made up for some of the lost sound in the Bose speaker set. Its not aftermarket quality mind you, but if you are on a budget and want a simple upgrade to your stock setup, that is one thing worth looking into.
    James Shafer
    St. Louis MO
  1. adding an aftermarket radio to bose/onstar/monsoon in 97-03 & 04-08 [*]
    By s1795so2 in forum How To Write-Ups/Tech Tips
    Last Post: 04-19-2010, 07:10 PM
  2. need upgrade help
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 01-28-2010, 11:33 AM
  3. Bose?
    By flynn in forum Audio, Security & Visual Electronics
    Last Post: 08-16-2008, 04:24 PM
  4. questions regarding adding an aftermaket cd player to bose/onstar
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 04:34 AM
  5. Aftermarket headunit install on BOSE system??
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 01-05-2008, 03:51 AM
