Thread: .... Noise again
Results 1 to 5 of 5
  1. #1 .... Noise again
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    I'm getting noise through the eclipse now. Seems to only do it with the car off(maybe just can't hear it while running lol) Anyone else have this problem? It's different than most noise I had. It's like I can hear the dvd/cd when you change tracks and mute it. No motor noise so kinda ruling out ground. Plus I'm using the factory ground wire. This car is very irritating
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  2. #2 Re: .... Noise again
    Saraland Alabama
    if the speakers are disconnected do you still hear it? I have never had noise with an eclipse, but the factory ground may be suspect
  3. #3 Re: .... Noise again
    Hoffman/Schaumburg, IL
    Do you have HID's??? cause they can cause interference
  4. #4 Re: .... Noise again
    Feb 2008
    Nashville
    It's was the god for saken Kicker amp. I put a Jl 300/4 in and nothing. I have had nothing but issues out the this kicker set-up and blamed it all on the HU's. I should have just stayed with the JL setup to begin with. I feel
  5. #5 Re: .... Noise again
    Saraland Alabama
    another reason kicker is not high end gear
  1. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
  2. Squealing Noise
    By eXceL(FAM) in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2008, 07:49 PM
  3. growling noise
    By tjs84c10 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-13-2008, 02:06 AM
  4. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
  5. GTP Tranny Noise, Need Help
    By GTPGP98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-28-2008, 05:08 PM
