Thread: Having a single box for a 15" JL Audio sub built
Results 1 to 20 of 26
nichol01gp Having a single box for a 15"... 07-11-2011, 10:05 AM
2000GTGP Re: Having a single box for a... 07-11-2011, 11:36 AM
speed demon Re: Having a single box for a... 07-11-2011, 06:15 PM
matt5112 Re: Having a single box for a... 07-17-2011, 07:29 AM
speed demon Re: Having a single box for a... 07-18-2011, 02:29 AM
Red1999GT Re: Having a single box for a... 07-17-2011, 04:05 AM
darkgreenmetallicgp Re: Having a single box for a... 07-18-2011, 12:58 PM
matt5112 Re: Having a single box for a... 07-18-2011, 01:02 PM
1LoudGrandPrix Re: Having a single box for a... 07-18-2011, 03:18 PM
speed demon Re: Having a single box for a... 07-18-2011, 09:14 PM
matt5112 Re: Having a single box for a... 07-18-2011, 10:46 PM
16MustangVet Re: Having a single box for a... 07-18-2011, 10:58 PM
matt5112 Re: Having a single box for a... 07-18-2011, 10:58 PM
16MustangVet Re: Having a single box for a... 07-18-2011, 11:00 PM
1LoudGrandPrix Re: Having a single box for a... 07-19-2011, 01:13 AM
rynoman03 Re: Having a single box for a... 07-19-2011, 02:08 AM
speed demon Re: Having a single box for a... 07-19-2011, 04:42 AM
rynoman03 Re: Having a single box for a... 07-19-2011, 04:45 AM
speed demon Re: Having a single box for a... 07-19-2011, 04:56 AM
rynoman03 Re: Having a single box for a... 07-19-2011, 05:53 AM
matt5112 Re: Having a single box for a... 07-19-2011, 09:46 AM
1LoudGrandPrix Re: Having a single box for a... 07-19-2011, 06:36 PM
speed demon Re: Having a single box for a... 07-19-2011, 09:09 PM
1LoudGrandPrix Re: Having a single box for a... 07-21-2011, 01:44 AM
speed demon Re: Having a single box for a... 07-21-2011, 03:26 AM
matt5112 Re: Having a single box for a... 07-21-2011, 10:30 AM
  1. #1 Having a single box for a 15" JL Audio sub built
    SE Level Member nichol01gp's Avatar
    Illinois
    OK so a guy is making me a single ported box for my 15" JL Audio sub. I dont really know what dimensions i should use, or cubic feet. I want to have really deep bass and as little as port noise as possible. Basically, i Just want this sub to hit hard and not lack sound quality. any help is appreciated. Thanks!
  2. #2 Re: Having a single box for a 15" JL Audio sub built
    Nov 2009
    illinois
    grab the model name/number off of the sub and google it for a spec sheet. You should be able to find how many cubes it needs as well as the dimensions.
  3. #3 Re: Having a single box for a 15" JL Audio sub built
    GTP Level Member speed demon's Avatar
    Apr 2011
    MICHIGAN
    ^x2,also make sure it's slot ported those boxes are way more musical than boxes with circle ports imo.
    '01 GTP: Rebuilt Trans by Andrew S....300m,hardened 4th,Transgo shift kit,V8 chain ect ect,3.8 MPS,ZZP 10.5.....More to come!
  4. #4 Re: Having a single box for a 15" JL Audio sub built
    Quote Originally Posted by speed demon View Post
    If its music you want, its ported you don't.
    Recommended sizes are a good start, but you can tune it further from there.
    LinearTeam
    That'll show you what each box does.
  5. #5 Re: Having a single box for a 15" JL Audio sub built
    Apr 2011
    MICHIGAN
    ^You're right Matt I shoulda worded that different ,basically go slot ported there is minimal to no port noise plus it helps the sub perform better.
  6. #6 Re: Having a single box for a 15" JL Audio sub built
    Jul 2011
    Pensacola, FL
    You can go to JL Audio's website and get recommended specs for the box you need to build, or feel free to look up JL Audio on facebook and ask there. A lot of helpful/knowledgeable people willing to help out
  7. #7 Re: Having a single box for a 15" JL Audio sub built
    SE Level Member darkgreenmetallicgp's Avatar
    Jul 2011
    Des Moines, IA
    The way iv'e always looked at it, is if you want LOUD, get slot ported. If you want louder, get bandpass, but they always sound like sh*t. If you want musical, Punchy bass, thats less boomy, go sealed.
    If you put a sub in the right spec box, it can be almost/just as loud as a ported box, with better sound quality.
    Dark Green Metallic, Gold Edition 2000 GT. Stock motor, Led's for all interior lights,6k HID's Pioneer HU, Alpine Compnent's, 12in Alpine Type R sub.
  8. #8 Re: Having a single box for a 15" JL Audio sub built
    Slot ports are terrible for turbulence.
    circular ports with flares fair better.
    If you want a terribly insane peak at 40 Hz, go ported.
    If you want to be able to hear each note at a somewhat similar sound level, try sealed.
    Again, try modeling the boxes first.
    you can make any style sound like anything you want with the right drivers and the right box.
  9. #9 Re: Having a single box for a 15" JL Audio sub built
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    or get a flat response box built like 20hz tuned
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  10. #10 Re: Having a single box for a 15" JL Audio sub built
    Apr 2011
    MICHIGAN
    Hey Matt,elaborate a little for me on what you mean by terrible for turbulence if you will bro,I've never heard that term used in car audio before.
  11. #11 Re: Having a single box for a 15" JL Audio sub built
    Example:
    Guy has a IB (infinite baffle, take Vas, multiply by 4, ideally 10, and that is the size of your box) setup in his attic.
    Thought he should try LLT (large low tuned ported box) so he ran two 10" ports per bank of drivers and still had issues with turbulance as in, he could hear the air moving and it detracted from the sound quality.
    Usually 27 m/s is your absolute max port velocity.
    ideally lower...
  12. #12 Re: Having a single box for a 15" JL Audio sub built
    slotted box tuned to 35hz with dremmel'd rounded corners made from 3/4 MDF thats what I had and loved it with 2 12s
  13. #13 Re: Having a single box for a 15" JL Audio sub built
    Ever hear of a router?
    And 35 is just right to emphasize that 40 Hz resonance our cars have....
  14. #14 Re: Having a single box for a 15" JL Audio sub built
    Yeah thats what I meant with a half round bit good catch lol
  15. #15 Re: Having a single box for a 15" JL Audio sub built
    Cedar Rapids, IA
    kerfed port
    i got some port noise from my 2 6in areos when they started to come unsealed
  16. #16 Re: Having a single box for a 15" JL Audio sub built
    Topeka, KS
    Wow didn't realize there was so much science in speaker boxes.
  17. #17 Re: Having a single box for a 15" JL Audio sub built
    Apr 2011
    MICHIGAN
    AHHH! i got ya matt that makes since, i guess i've just alway's been a slot ported guy every since i've been putting sounds in my cars which have all been pontiacs, i guess it's just a matter of preference, slots just sound nominally better to me and the low end the slot catches is wonderfull,that's the setup i have in the GTP right now 1 15 inch sub in a slot ported box built over specs (not a whole lot over) and a 1500 wtt amp and i can knock earings out ya ear with it,but you make alot of since in what you said sir that is definately something to consider.
  18. #18 Re: Having a single box for a 15" JL Audio sub built
    Topeka, KS
    I've always liked the sealed myself but the slotted tuned boxes sound interesting. There was a guy back when i was in HS that had 4 Pioneer Premier 12's running off memphis gold amps in a Plymouth Breeze with a home built slotted setup. Loudest damn car i've ever rode in or heard. Crazy Loud!
  19. #19 Re: Having a single box for a 15" JL Audio sub built
    Apr 2011
    MICHIGAN
    I love'em honestly but it really is a matter of preference to what you like your sounds to sound like,it is definately worth trying you just might wanna make sure the person who builds the box doe's it for the love of the sounds and not the love of the money. I can definately believe that ryno, i saw a guy with 4 alpine type r's in a chevy caprice with 4 of the alpine 1000's interlinked running to them in a slot ported box and let me tell you i sat in the car for maybe a total of 45 seconds before i started feeling sick to my stomach,so yeah i can definately say slot ported doe's do wonderful as well as circle ports and sealed.
  20. #20 Re: Having a single box for a 15" JL Audio sub built
    Topeka, KS
    Holy triple post batman.
  1. Single Tweeter setup -- Let's add some jazz to the audio forum
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 01-12-2010, 05:26 PM
