Thread: climate control swap
Results 1 to 4 of 4
  1. #1 climate control swap
    GTP Level Member 2001goldGTP's Avatar
    california
    anyone ever change the anolog switch climate controller to a digital one from a gp that had the digital one? does it work?
    xp'd
  2. #2 Re: climate control swap
    you cant, completely different wire harness.
  3. #3 Re: climate control swap
    california
    damn,
    dream........
    crushed.........
    xp'd
  4. #4 Re: climate control swap
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    It's more than just the wiring. You need the blow motor module, the vacuum solenoid, temperature valves and actuators. If you're removing the dashboard to do some work, it's not too bad. But you do have to remove the dashboard to get to the parts you need. Definitely not an hour job of soldering a few wires. I used compnine to find the differences because I was changing my I/P wiring harness. I'm out of work, so I had the time to do it.
  1. climate control
    By gtcoup in forum Off Topic Discussion
    Last Post: 12-19-2010, 11:04 PM
  2. Climate Control
    By GrandprixGearhead in forum General Tech Discussion
    Last Post: 10-30-2009, 11:47 AM
  3. Attempting '97 Dual Climate Control Swap- Building shopping list
    By JBONE in forum General Tech Discussion
    Last Post: 09-17-2009, 11:20 AM
  4. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
