Thread: Good Easy to Install Replacement Tweeters?
Results 1 to 20 of 31
  1. #1 Re: Good Easy to Install Replacement Tweeters?
    Indianapolis
    I'm not sure if I understand what youre saying about the rear speakers but if the bass starts to distort when you turn the volume up your rear speakers are probly blown and need replaced
  2. #2 Re: Good Easy to Install Replacement Tweeters?
    Jun 2011
    Detroit, MI
    Quote Originally Posted by TheNoob23 View Post
    It just sounds like I'm gonna blow out the speakers on lower volume when I flat-line the EQ. And the bass at higher volumes, flat-lined sounds... not really distorted, just... bad, and i really like a lil' extra bass most of the time!
    iLoveSpade
  3. #3 Re: Good Easy to Install Replacement Tweeters?
    Feb 2009
    Virginia
    Quote Originally Posted by Hippo Machine View Post
    You're getting into physics. There's a reason why you have a tweeter and mid. There's a reason why quality installations have sub-woofers. A mid-woofer can't play a 20hz frequency very well at all. It will end up damaging the voice coil before anything good happens.
    Bottom line, you either have a speaker that can play as low as 20hz or you don't. Most mid-woofers do NOT play well below ~50hz. Mid-ranges typically don't play well below 125hz. A mid-woofer includes a mid-range and a tweeter. Two way setups which is what's installed in our vehicle are better at one, the other, or play both kinda blah.
    So if you want a speaker that plays decent below, 125hz in our vehicles, you need a sub or at a minimum 3-way speaker setup. Even then, you need a sub if you have music that reaches deep.
    11 is louder than 10!
  1. How to install headers: The easy method
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 01-02-2017, 05:41 PM
  2. Easy way to install a new wheel stud?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 08-12-2010, 05:44 PM
  3. --> Serpentine Belt & PULLEY Replacement Install H@lp <--
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2009, 11:29 PM
  4. New Photoshot/Good Pictures Of 03-04 Headlights After Install
    Last Post: 12-06-2008, 01:12 AM
  5. Tweeters
    By speedemongtp in forum Audio, Security & Visual Electronics
    Last Post: 10-29-2008, 03:47 AM
