Thread: HID kits?
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #1 Re: HID kits?
    Kansas
    Quote Originally Posted by bziggy58 View Post
    as i said im new to HIDs but what is the deal with this harness im seeing on DDM tuning website? its an option with the HIDs
    The wiring harness is to give the ballast good solid current and ground. Instead of pulling all the power from factory small gauge wires, it's pulling straight from battery. And is also good to prevent frying your stock wiring harness. I run a 55W and 35W without a wiring harness for over a year, and never had any issues.
  2. #2 Re: HID kits?
    SE Level Member bziggy58's Avatar
    Apr 2011
    Minnesota
    i gotcha, makes sense i guess. pulling that wattage with such a small wire. does the slim ballast just mean the ballast is slimmer i assume, is that a big deal?
  3. #3 Re: HID kits?
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    The slim ballast is just that, A slim ballast. Its supposed to be smaller than the normal ballast meaning you can tuck it away alittle better. I went with the slim ballasts from the get go and tucked them away niceley. I dont see where there would be a problem with the normal sized ones though. There is plenty of space behind your headlights to put several ballasts. I have 2 on each side and have no issues.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  4. #4 Re: HID kits?
    Apr 2011
    Minnesota
    ok thats what i figured, just seen the slim one was a little more money. Once the projectors come and i get them in, im gonna do 55w 10000k on the highs and 35w 8000k on the lows, does that sound like a nice setup? i want the blue look but i want enough light to see
  1. JLM HID kits
    By Jakescoots in forum Visual/Body Modifications
    Last Post: 12-31-2010, 10:51 AM
  2. JAW Kits
    By Ibwrong in forum General Tech Discussion
    Last Post: 06-09-2010, 08:23 AM
  3. HID Kits
    By webracin in forum Group Buys
    Last Post: 07-08-2009, 10:26 PM
  4. body kits,
    By stanwich in forum Visual/Body Modifications
    Last Post: 11-14-2008, 09:23 PM
