Thread: Wiring Help!!
Results 1 to 9 of 9
  1. #1 Wiring Help!!
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Alright so I got this cutout and 12volts dc and heres a pic of the wires coming from it.
    its got some kind of connector which the guy didnt have the other end to so I was planning on chopping that off and soldering my wires to it.
    Heres the part thats a little bit more tricky the switch has four wires coming from it.
    and I heared that you can just use the cigerette lighter as your power source and ground is that true?
    my other question is from the switch I have one red one black and a white and a green whats the deal with the white and green I assume the with is the ground correct? I guess what I don't get is I know I need two wires coming into the switch with power and then I need two wires going out or possibly one wire going out and the other already going too the cutout and then the switch would complete the circuit.
    I haven't done anything like this in awhile so if someone could help make sense of this for me that would be awesome
  2. #2 Re: Wiring Help!!
    Dec 2010
    Ohio
    anybody?
  3. #3 Re: Wiring Help!!
    Dec 2010
    Ohio
  4. #4 Re: Wiring Help!!
    One common ground, one to open, and one to close? Hook it to a battery and see what it does.
  5. #5 Re: Wiring Help!!
    Jan 1970
    Maquoketa, Iowa
    What brand of cutout is it? It's not just an on/off kind of thing its a open/close action.
  6. #6 Re: Wiring Help!!
    Dec 2010
    Ohio
    its a Dmh
  7. #7 Re: Wiring Help!!
    Dec 2010
    Ohio
    bump
  8. #8 Re: Wiring Help!!
    GTP Level Member
    Pittsburgh
    Red and Black from the switch go to power and ground, Green and white from the switch go to Red and White on the cutout
    2003 SSEi,
  9. #9 Re: Wiring Help!!
    Dec 2010
    Ohio
    alright thx, does anyone know how to pop the cigerette lighter out? I'm probably just going to cut the thing off completly since I don't use it
  1. Amp and sub wiring
    By beerfun in forum Audio, Security & Visual Electronics
    Last Post: 08-24-2010, 01:33 AM
  2. wiring help.
    By chunky in forum Audio, Security & Visual Electronics
    Last Post: 11-22-2009, 03:09 PM
  3. Please help!! EGR wiring
    By Red97GPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2009, 11:30 AM
  4. Help with LED Wiring?
    By FastKatt in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2009, 10:28 PM
  5. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
