Thread: how to remove rear speakers ??
Results 1 to 17 of 17
  1. #1 how to remove rear speakers ??
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    i know where the speakers are and what size but i have no clue how to get the plastic cover off without breaking it . i figure since i have the use of this forum i might as well ask before i break the covers . . please help . are they just simple pop offs or are there some hidden bolts or tabs i need to remove first ?
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  2. #2 Re: how to remove rear speakers ??
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    you dont get the plastic covers off they are stuck in, Believe me as much as I switch speakers to find one I like, I tryed to find a short cut. You have to take the rear package tray off, and almost all the time the back seat, especially 97-03's.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  3. #3 Re: how to remove rear speakers ??
    Milpitas , Ca.
    that sucks
  4. #4 Re: how to remove rear speakers ??
    Milpitas , Ca.
    ok so how do i take off the back tray ??
  5. #5 Re: how to remove rear speakers ??
    alhambra, Il
    Removal rear cushion:
    1. Pull cushion release tabs and remove cushion
    Removal rear seat back:
    1. Remove small nut on each side of bottom
    2. Remove large nut on each side of bottom also holds seat buckles
    3. Top is just held in by hooks. Pull bottom off of mounting bolts and lift to remove
    The package tray then needs to be pulled up slightly and then it should be able to pull out. Boom and you can get to your speakers.
    Steven Oliver
  6. #6 Re: how to remove rear speakers ??
    Milpitas , Ca.
    doesnt sound to bad .
  7. #7 Re: how to remove rear speakers ??
    alhambra, Il
    Nope it really isn't. But after you do it a gagillion times it gets a lil old.
    Steven Oliver
  8. #8 Re: how to remove rear speakers ??
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    how many is a gagillion? if it's alot, i'd like a gagillion dollars!
  9. #9 Re: how to remove rear speakers ??
    GXP Level Member ryangtp89's Avatar
    Maine
    Quote Originally Posted by Toasty View Post
    lol me too please!
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  10. #10 Re: how to remove rear speakers ??
    alhambra, Il
    It is just a lil' big of a number, haha
    Steven Oliver
  11. #11 Re: how to remove rear speakers ??
    Jan 1970
    Maquoketa, Iowa
  12. #12 Re: how to remove rear speakers ??
    Milpitas , Ca.
    thanks for that link that helps alot !
  13. #13 Re: how to remove rear speakers ??
    SE Level Member yourTVlies's Avatar
    Quote Originally Posted by FoSHO99 View Post
    This is stellar. Can someone confirm if the process for accessing speakers on the '04-'08s (specifically the 2006GP) are similar? I bought a bunch of the gear I want to install in my rig from Crutchfield, but for a different car three or so years ago - I wonder if they'd send me a mastersheet as part of the their "lifetime support" deal.
  14. #14 Re: how to remove rear speakers ??
    Saraland Alabama
    takes me about an hour total to pull the seat, and speakers and replace everything (this includes the cleanup from the babies car seat and the 6 year old)
  15. #15 Re: how to remove rear speakers ??
    Jan 1970
    Maquoketa, Iowa
    I took everything apart with the help of my little brother, little did I know where he put all the clips/bolts so I'm currently in the process of figuring that out until next weekend... so I've been driving around like this-
    Had to do little cutting to this bracket to get the new speakers to fit in the front, I had to cut the backplate of this bracket out...
  16. #16 Re: how to remove rear speakers ??
    May 2008
    McHenry IL
    easy to access rear speakers follow the diagram fosho got for you its easy but kinda annoying.
  17. #17 Re: how to remove rear speakers ??
    Good news - the above PDF helped me along, but the process is indeed different for the newer models. In the 04-08s you've got to deal with the C post trim and a few more screws securing the seatback. I took some pictures with my phone during my install, and I'd be happy to do a writeup if there's any interest.
  1. How to remove the supercharger ?
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 04:20 PM
  2. Rolling Your Rear Fenders Option #1 [*]
    By TommyGloves in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2009, 08:52 PM
  3. Rolling Rear Fenders Option #2 [*]
    By VinnieGTP in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2009, 08:51 PM
  4. How to remove the ashtray?
    By IndeedSS in forum General Tech Discussion
    Last Post: 01-20-2008, 06:44 PM
  5. Rear door will not shut *Solved*
    By Fish in forum Visual/Body Modifications
    Last Post: 12-25-2007, 02:53 AM
