i was curous what you guys use to clean subs up ive just wiped them down with a rag but they are starting to lookso i was wondering if there was a chemical that would be safe for the suround.
thanks
justin
thanks
justin
I have used just regular glass cleaner on a rag (don't spray them directly) with no adverse effects
I don't use glass cleaner. Most of those have ammonia, which is way too strong of a chemical to be cleaning my expensive subs with.
What I do is disconnect everything and use a dry microfiber cloth. If something is truly dirty, I will use a drop or two of a non-residue leaving detergent (like Ivory) in some water to wipe it down, then go over that with another cloth with just plain water just to make sure, then dry it with the micofiber.
Hope that helps.
Invisiglass
If your talking about just the cone of the sub I use armor all wipes.
i switch out my subs way to often so i never have to clean them![]()
You guys do have some valid points there...
