Thread: Fog Lamps/Lights
Results 1 to 5 of 5
  1. #1 Fog Lamps/Lights
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    My fog lights won't turn on, and neither does the button inside. This only happened after I got some speakers and a new stereo installed. I bought a new fuse and a fuse relay to see if that solved the problem, but nope, it didnt do anything. Even if the bulbs were burnt out, the button inside would still light up. But nothing's lighting up, not the button, nor the fogs.
  2. #2 Re: Fog Lamps/Lights
    Nov 2010
    Michigan
    Any idea why they wont turn on?
  3. #3 Re: Fog Lamps/Lights
    GTP Level Member simbah's Avatar
    Lala land
    Who/where did your installation?
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  4. #4 Re: Fog Lamps/Lights
    Nov 2010
    Michigan
    Some store I know from work called Hollywood Sound.
  5. #5 Re: Fog Lamps/Lights
    Lala land
    I would go and talk to them to see if maybe they did someting like not plug the switch back in behind the panel or check it out yourself.
  1. Fog lamps ????
    By vondoom88 in forum Visual/Body Modifications
    Last Post: 10-19-2010, 05:39 PM
  2. Blazertech fog lamps?
    By bigtom9492 in forum Visual/Body Modifications
    Last Post: 05-30-2010, 02:21 AM
  3. Fixing leaking corner lights, through lamps.
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 04-21-2008, 09:39 PM
  4. looking for new fog lamps
    By ayman in forum Visual/Body Modifications
    Last Post: 04-03-2008, 11:30 AM
