Thread: Disabling Auto Lights...?
Results 1 to 12 of 12
  1. #1 Disabling Auto Lights...?
    SE Level Member 97GTzbban1's Avatar
    Royal Oak, MI
    I would like to be able to disable the auto on lights in my car, '97 GP GT. I do not have DRL, just the auto ons. I have checked out this website for directions and just want a little clarification on something. Refer to the first picture on the right......
    Headlamp Control
    I'm assuming that you have to take out the oblong shaped part on the dash, close to the center of the windshield, where the little sensor is and then just plug the fuse-looking resistor into something on the bottom of that part? I haven't yet pulled this part, just trying to see if it's something that I could do myself first. Electronic stuff isn't my high point...lol. Anyway, if that's basically how I do it, then where would I buy something like the resistor? Radio shack? What do I ask for, a "fixed 470-Ohm resistor"? Should I take the pic of said resistor along with me and show them what I need?
    And how do I get that part out of the dash...pry it up carefully with a screwdriver or what? Thanks in advance...
    Nancy
    1997 GT bone stock.
  2. #2 Re: Disabling Auto Lights...?
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    find the fuse for the Twilight sentry and pull it out ... done.
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  3. #3 Re: Disabling Auto Lights...?
    Royal Oak, MI
    Really? It's that easy? I think I read somewhere that just pulling a fuse related to the auto ons may cause the check engine light to come on......is that true or can I just pull the fuse and be good to go? Where is this fuse located? I'm assuming that it may be one of the bigger fuses in the engine compartment fuse box?
    1997 GT bone stock.
  4. #4 Re: Disabling Auto Lights...?
    GT Level Member chickenfried's Avatar
    Feb 2010
    Gilman IA
    i pulled the drl fuse out of the fuse block in the glove box and that took care of mine.
  5. #5 Re: Disabling Auto Lights...?
    same and I've been driving around like that for 3 months with no SES light,
    *image too tall*
  6. #6 Re: Disabling Auto Lights...?
    Feb 2010
    Gilman IA
    Quote Originally Posted by Biohazed View Post
    mmhmm x2
  7. #7 Re: Disabling Auto Lights...?
    Royal Oak, MI
    Sounds like this is the fix....will attempt to find the fuse later, will report back either way.
    1997 GT bone stock.
  8. #8 Re: Disabling Auto Lights...?
    GT Level Member kjclawson's Avatar
    Fort Myers, Florida
    look in your manual for the fuse number...
  9. #9 Re: Disabling Auto Lights...?
    Royal Oak, MI
    Quote Originally Posted by kjclawson View Post
    I would, IF I had a manual...lol. Bought it used and it didn't have one. Been busy this afternoon, but hopefully will be able to get to it later this evening.....
    1997 GT bone stock.
  10. #10 Re: Disabling Auto Lights...?
    Royal Oak, MI
    Quote Originally Posted by chickenfried View Post
    Yep, that did the trick....thanks!!
    1997 GT bone stock.
  11. #11 Re: Disabling Auto Lights...?
    if you have drls and pull the diode connector thing in the dash to disable them and then if you pull the drl fuse, would that disable the auto lights also?..and another thing would disabling the auto lights, also keep the lights from flashing when you lock and unlock the doors?..because im trying to do that also but cant figure it out
    SMGPFC Member #10
  12. #12 Re: Disabling Auto Lights...?
    Dec 2008
    Lawndale, CA
    Pulling the drl just disables the drl's. The fuse for the auto lights only works on certain years. I want to say that 01+ have issues with pulling the fuse to disable the auto lights. Disabling the auto lights does not disable the headlights from flashing. The manaul has the procedure to set up the alarm system. Or based on a certain year you could wire the headlight flash to the corner lights.
  1. auto lights
    By big ben in forum General Tech Discussion
    Last Post: 01-19-2011, 05:58 PM
  2. disabling auto headlights
    By Jakegday in forum General Tech Discussion
    Last Post: 11-15-2008, 01:23 PM
  3. Blower and Auto Head Lights quit working
    By timothy_tw in forum General Tech Discussion
    Last Post: 10-30-2008, 10:34 AM
  4. Group Buy Update (Spyder Auto Projector Head lights)
    By john@SpyderAuto in forum Visual/Body Modifications
    Last Post: 04-30-2008, 04:31 PM
