Thread: Stock Deck.....
Results 1 to 18 of 18
  1. #1 Re: Stock Deck.....
    Houston
    If you really wanna keep the stocker, you'll need an in-line converter to get your signal, then you've got everything you need. The problem with that is...if you wanna turn the bass up you will have to bring the bass up in the mids as well, and it will distort and blow the rest of your speakers.
  2. #2 Re: Stock Deck.....
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Some amps have it so you can adjust the bass and everything right on the amp.
    As with the the other thing do you always want your subs come on or do you want them on a switch to turn them on and off.
  3. #3 Re: Stock Deck.....
    Houston
    Quote Originally Posted by csssaint12 View Post
    Every amp these days do, but if you're running of the stock radio, the only way to turn the bass up on the subs is to turn up the bass on the deck. Which will bring the bass up on all of the speakers. Unless you have a remote bass knob.
  1. Does the Stock deck have RCA outputs
    By jacobmh27 in forum Audio, Security & Visual Electronics
    Last Post: 09-22-2010, 12:51 AM
  2. Subs with stock BOSE deck
    By thumper in forum Audio, Security & Visual Electronics
    Last Post: 02-25-2010, 10:41 PM
  3. Pulling Stock Deck
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-07-2009, 03:55 PM
