Ok, as u all might of read my other thread, my amp Wasent working. Idk if dis has happened 2 any1, but my r.c.a. wires burnt out. I have absolutly have no idea y. Might any1 have an idea y? & They weren't cut or anything.![]()
I'm pretty good at solving wiring issues if the issue is described in english...
Ohhhhhh, I think dey r, 16 gauge. & I found out dat in some parts of the r.c.a. wires it is, yellow & silver, through the outside only.
Maybe I'm being a jerk but could you provide a photo? I can't quite picture what you're trying to say.
You should only see two wires per RCA, sounds like you've already resolved that. One of them is sheathed. Please convey "burnt out" RCA's with a picture too!
I've tried 2 upload pics. several times, it doesn't let me, it always says, "file upload failed", every single time.
So I tryed out da r.c.a. wires on some speakers & they still work, Idk y it didn't work on my amp. But anways I think my amp burn out.
You should try photobucket or another host for your pictures.
Anyways, I highly doubt you fried your RCA's. Your head unit doesn't throw enough through those wires for anything to be "burnt"...ever. Even if there was a macrocosm of events that shot a spike through the RCA's, it still wouldn't be enough to "fry" them. That's because the total power that your head unit draws isn't enough to damage an amplifier or even the cables through the length of your vehicle.
Sounds like your amp is damaged and whenever that cap or whatever it was went, it through a surge. Electricity is ALWAYS looking for a place to go. When your ground is overwhelmed those surges go wherever there's a wire willing. Apparently, that surge reached out to your RCA's too. Good thing the components leading out to your RCA's can't take that much abuse or else you'd probably be replacing a head unit as well.
It honestly sounds like you had a bad setup. That doesn't necessarily mean that all your wiring was bad or the amp is a piece. It means that tuning, install, and proper setup should all be questioned at this point.
Before you throw something else in I'd make certain that you install correctly. That means verifying your entire thought process with an experienced individual prior to throwing that volume knob. Just because it does fine at low listening levels doesn't mean it's operating correctly either.
I'll help if you want but I would request that you provide photos of the install and even pictures of the crossovers as well as gains. I'd also need all technical information for the equipment being used.
But I found out it wuz my amp, it burnt out cuz I have 2 12's, quauntum cozmik series (1500rms, 3000max) & I had em lowered down 2 1 ohm, & my amp wuz a kicker zx 300.1, it wuz basically killing it, little by little, anyways now I got a Sony X-Plod 1000w. & they are bumping bada§§! Thanxs guys 4 all da help, I really appreciate it.
4 reals I lowered 1 to 1 ohm, & da other 1 regular, & I hooked em up 2 my amp, & da 1 dat I lowered, I could hear it better than da regular 1.
