Thread: post you amp rack(s)
Results 1 to 17 of 17
  1. #1 Re: post you amp rack(s)
    Feb 2009
    Virginia
    Quote Originally Posted by tc300 View Post
    for you guys that put there amps upside down to the rear deck ,do you just bolt them metal to metal or is there a piece of wood..??
    If you look through the links in my sig you'll see that I did use a board. My amplifier has the heatsinks mounted to the sides so that inverting the amp won't effect it's ability to dissipate heat.
    I don't quite remember what I used to mount the wood on the rear deck but it's probably along the lines of nylon spacers along with a bolt and lock washer+nut?
    That's a very nice BA amplifier! Wish I could hear your installation. You picked a very nice sub too. There's nothing wrong with overboard if it gives you piece of mind. It also helps to line everything to prevent panels from rubbing. Otherwise, 25% coverage moves 90% of the resonance to a lower frequency.
    11 is louder than 10!
  2. #2 Re: post you amp rack(s)
    SE Level Member hanback's Avatar
    Indiana
    When I had it all in the car, it looked like this.
    The box istn't carpeted in the pic yet because I took this the day that I got it all together and never got a picture of the box after carpeting. It is kind of hard to see, but I just mounted the amp right on top of the box. Ran the audio wires to the right, and the power wire to the left. It was easiest for me this way, and the amp is not really that visible.
    My former pride and joy....2002 Grand Prix GT
  1. rack and pinion
    By 2005GrandPrix in forum Brakes/Suspension/Chassis
    Last Post: 02-21-2011, 09:53 AM
  2. steering rack
    By GTP Ryan in forum General Tech Discussion
    Last Post: 11-22-2010, 04:04 PM
  3. roof rack?
    By speedemongtp in forum Visual/Body Modifications
    Last Post: 08-03-2010, 07:57 AM
  4. Replace Magnasteer Rack with Regular Rack?
    By Smoker324 in forum General Tech Discussion
    Last Post: 06-29-2010, 09:11 PM
  5. Help me design a amp rack!
    By Toofastgs in forum Audio, Security & Visual Electronics
    Last Post: 02-19-2009, 04:19 AM
