Thread: AUX Port...?
Results 1 to 20 of 20
  1. #1 Re: AUX Port...?
    Edmonton AB
    I have done this in my 07 Grand Prix GT with the monsoon.
    Precision Interface Electronics GM12-AUXv2 Connect a portable music player, satellite radio tuner, or DVD player to your factory GM receiver at Crutchfield.com
    Plug in and play. You'll need to tap into the power (thicker yellow cable from the connector from inside of the car) and then get a RCA to Aux so you can play your tunes.
    Hope that helps,
    -Garrett
  2. #2 Re: AUX Port...?
    GTX Level Member Confusingboat's Avatar
    Minnesota
    Quote Originally Posted by garreTT View Post
    Hope that helps,
    -Garrett
    Go straight from the fusebox. NEVER take power from the head unit.
    2004 Grand Prix GT2 - SOLD
    2015 Evo MR
  3. #3 Re: AUX Port...?
    Edmonton AB
    Quote Originally Posted by Confusingboat View Post
    Any reason why? How would you hook it into the fuse box? My fuses are all on the passenger side of the car.
  4. #4 Re: AUX Port...?
    Minnesota
    Well first off you'd be hacking up the factory wiring lol, then there's the fact that the head unit has a built in amplifier (non-monsoon). Also everyone I've ever talked to has said to never take power from the HU so there's that, but I can't speak to the credibility of such statements. Look up add a fuse on Amazon, and there's a big metal piece in the fuse box with a hole in it I use for a common ground. You can just run the wires through the bottom of the dash under the paneling, completely out of sight.
    2015 Evo MR
  5. #5 Re: AUX Port...?
    one of these puppys work great, every auto parts store has them in the fuse section.
    Littelfuse FHA200BP ATO Fuse Add-A-Circuit KT
  1. port plans
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-02-2010, 06:46 AM
  2. How hard to port?
    By dagger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2010, 12:49 PM
  3. My S/C Port
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2009, 01:54 PM
  4. How to port your m90.
    By minichopper6hp in forum How To Write-Ups/Tech Tips
    Last Post: 09-03-2009, 04:32 PM
  5. Port my LIM???
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 09:50 PM
