newer cars dont like the DRL fuse being pulled.
they make an awful noise till you put the fuse back in.
You are right. I believe this is true for 00-03's. It's best to just unplug the DRL diode in the drivers side compartment. As stated, unplugging the connector will still keep the auto headlight feature. If you want to disable the auto headlight feature then do what is written in this link.
Headlamp Control
