Thread: Dim interior lights help
Results 1 to 8 of 8
  1. #1 Dim interior lights help
    Dec 2010
    Grand Forks, ND
    I cut the trunk courtesy light wires in the trunk to put some new LED strips and now all of the interior lights in the car are dim. The trunk LEDs don't light up bright at all, and when i complete the circuit all of the lights in the interior shut off, but are dim when the circuit is not complete. Any ideas?
    Thanks
  2. #2 Re: Dim interior lights help
    Dec 2010
    Grand Forks, ND
    1998 GP SE by the way
  3. #3 Re: Dim interior lights help
    have you held the wires togeter where you cut them(not with the leds just wire to wire
  4. #4 Re: Dim interior lights help
    Dec 2010
    Grand Forks, ND
    Yes, and the interior lights shut off.
  5. #5 Re: Dim interior lights help
    did you cut them before the socket or just splice into them
    if you just cut the socket off then when you touch them together then it may be tripping a ciruit breaker and shutting the lights off or blowing a fuse
  6. #6 Re: Dim interior lights help
    Dec 2010
    Grand Forks, ND
    i cut the socket off because the socket was melted. Once i did that the interior lights went dim inside the car. I then wired up the LEDs and they hardly lit up so i unwired the LEDs. Then i touched the two wires together and the interior lights shut off completely, and when i pulled them apart the interior lights came back on but were dim.
  7. #7 Re: Dim interior lights help
    SE Level Member carjunky102's Avatar
    Nov 2010
    Negley, Ohio
    If the lights are still on then there is nothing wrong with the fuse or bulbs themselves. The problem is more than likely loose connections or a bad ground. Those are both common problems with dim lights. Check your wires that you cut to hook up the Leds. Make sure that they are secure connections. If they are soldered, make sure the solder is melted enough.
  8. #8 Re: Dim interior lights help
    Dec 2010
    Grand Forks, ND
    i wired and soldered everything up real nice and the interior lights are completely off now that the circuit is complete.
  1. Interior LIghts
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 01-27-2011, 10:01 PM
  2. Interior lights not working
    By jmanrta in forum General Tech Discussion
    Last Post: 11-30-2010, 12:37 PM
  3. LED interior lights
    By joliver2011 in forum Visual/Body Modifications
    Last Post: 02-14-2010, 09:45 PM
  4. problem with the interior lights?
    By riseagainst4288 in forum General Tech Discussion
    Last Post: 07-24-2009, 08:37 PM
  5. Interior Lights:(
    By RichCresci in forum General Tech Discussion
    Last Post: 07-08-2008, 11:29 PM
