Thread: So, I'm back in the GP mix again! HUD question?
Results 1 to 6 of 6
  1. #1 So, I'm back in the GP mix again! HUD question?
    SE Level Member Jcal1120's Avatar
    Watertown, MN
    Well, I've had a 2000 Grand Prix, then an 04 GT2, been rockin a G6 GXP of late, and I just couldn't stay away. Picking up an 04 GTP tomorrow, only issue is the HUD isn't showing any output on the windshield. Ideas to start with once I get my hands on it? Burnt out bulb? What else goes wrong with the unit?
  2. #2 Re: So, I'm back in the GP mix again! HUD question?
    SE Level Member Dan71's Avatar
    Apr 2011
    Sterling Hts. MI
    http://www.grandprixforums.net/how-f...3-a-39798.html
    usually thats all there is to it...
  3. #3 Re: So, I'm back in the GP mix again! HUD question?
    04 and up suffer a different HUD issue. They have a broken clip or something and popping in there and fixing it is quick and easy.
  4. #4 Re: So, I'm back in the GP mix again! HUD question?
    Feb 2009
    Virginia
    The piece of plastic holding the spring...responsible for moving your HUD up and down in the windshield, tends to break. Crack it open and attach that spring again. There's a thread somewhere
    11 is louder than 10!
  5. #5 Re: So, I'm back in the GP mix again! HUD question?
    Apr 2011
    Sterling Hts. MI
    ^^ This is right, apparently I dont read years when I'm answering questions drunk at 3am Thanks for the correction
  6. #6 Re: So, I'm back in the GP mix again! HUD question?
    New Brunswick
    Also be careful removing the trim, very easy to break if you rush it. Once it's unsnapped if you hold it against the windshield it's easier to lift it away without the clips scratching the dash or anything.
  1. Car is back!
    By coreygnar in forum Off Topic Discussion
    Last Post: 06-14-2010, 10:59 PM
  2. Back Again
    By Willthesage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2009, 11:10 PM
  3. need help getting my back window back on track
    By GrandPrixGT00 in forum Visual/Body Modifications
    Last Post: 06-15-2009, 04:06 PM
  4. Back on here.
    By Dohner in forum Off Topic Discussion
    Last Post: 05-12-2009, 08:49 PM
  5. I'm Back!!!
    By pissedoff02grandprix in forum Off Topic Discussion
    Last Post: 02-12-2009, 07:50 AM
