Thread: Where to run power wire?
Results 1 to 20 of 22
  1. #1 Re: Where to run power wire?
    Jersey
    a clothes hanger wire is my favorite tool for running amp wire, i ran new wire in this kids 00' grand prix and made a slit through the rubber groumet for the power wire so there wasnt a huge hole in the fire wall
  2. #2 Re: Where to run power wire?
    SE Level Member reallyfast1's Avatar
    Aug 2008
    CAMBRIDGE,ONTARIO,CANADA
    i went through the pas. side where the door electronics come out then i went through the fender above the wheel, then pull it out right behind the front headlight, did this with the good old coat hanger!! its a fast and clean way to do it!! if u want pix ill post them!!
  3. #3 Re: Where to run power wire?
    Donating Users crshoveride's Avatar
    Pearl, MS
    that's what i did. it's like a 2 piece grommet. the innermost will pop out and then it just takes a screwdriver like everyone else said. it'll pop right through. that's how i did it.
    1998 Grand Prix GTP Stock for now mods to come soon. Alpine 9885 head unit, 2 JLW3V2 10s, 2 Jensen 650x2 amps, and Tsunami wiring all the way around.
    Ladies and gentleman take my advice. pull down your pants and slide on the ice
  4. #4 Re: Where to run power wire?
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by 99prixgt View Post
    did the same through the rubber...although i had to hella tape the wire to it...almost lost it but it came thru...like everyone said be sure to stick a nice sized screwdriver in there to open it up...
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  5. #5 Re: Where to run power wire?
    SE Level Member Hayden's Avatar
    Aug 2008
    Michigan
    You would think these car manufacturers would think of making an accesories hole in the firewall for all the electronic gizmos these days. ARE YOU LISTENING GM
  6. #6 Re: Where to run power wire?
    Saraland Alabama
    Quote Originally Posted by Hayden View Post
    the problem is they don't want you adding any electronic gizmo, they want you to buy their top of the line junk, never aftermarket
  7. #7 Re: Where to run power wire?
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by archemedes View Post
    good-one
  8. #8 Re: Where to run power wire?
    GT Level Member adidasdude1061's Avatar
    Jul 2008
    P-Town, MN
    So if I am doing this right, I am having my wire actually running underneath the car for quite a bit am I right? I live in MN, and there is the dreaded salt and chloride on the roads, and I am little worried about my wire rotting away. Any suggestions other then running it through the pass door?
    '97 BLACK GTP--Chrome K&N CAI--3.5" MPS--3" RT Cat Downpipe--180*Tstat--Tuned PCM--Alpine 9886--Kicker Amp - 2 12" Kicker L7's--ALT boost&rewire
  1. Engine Ground to Chassis wire
    By AlmightyBirdman in forum Audio, Security & Visual Electronics
    Last Post: 06-18-2008, 07:39 AM
  2. OBD 2 wire
    By bula81069 in forum PCM Tuning
    Last Post: 04-14-2008, 11:25 AM
  3. Need more power help!!!
    By bkaab in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-02-2008, 09:02 PM
  4. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
