Thread: want to remove guages. dont know how
Results 1 to 9 of 9
  1. #1 want to remove guages. dont know how
    Jacksonville, Fl
    I bought my gp from A rycer. He had a pillar gauge with jdm guages. I want to remove them but I'm not sure how. I'm pretty good mechanically. but electronically, I got a negative IQ. Can someone please explain how to remove them? They're fed through the dash so I already know I have to pull that.
  2. #2 Re: want to remove guages. dont know how
    Nov 2010
    Marine City MI
    What gauges are they specifically? Oil pressure? Boost? Volts?
    99 GTP, ZZP MPS 2.9 pulley, GenIII supercharger ported & polished, machined intake W/ stage 2 intercooler, XP Cam,ZZP fuel rails, 42.5 injectors, Wizard CAI, custom headers, 3 inch downpipe, into dynomax muffler,180 stat, Northstar TB, 85mm MAF, ZZP trans, 3.29 gears, input shaft and torque converter, stock heads W/Ls6 springs.
  3. #3 Re: want to remove guages. dont know how
    Omaha, NE
    I'm assuing its an A pillar gauge, just pull the pod out. it should just have clips holding it in.
    You shouldn't need to pull the dash to remove the wiring.
  4. #4 Re: want to remove guages. dont know how
    if you are electrically dumb and dont want to screw anything up then cap off all the wires individually and tuck them up somewhere.
  5. #5 Re: want to remove guages. dont know how
    Jacksonville, Fl
    The gauges are oil temp, boost and air/fuel. I would like to completely remove the excess wire cause even if there out of sight, it will just me nuts knowing they there
  6. #6 Re: want to remove guages. dont know how
    besides the air/fuel gauge, the others are useful. id swap the air/fuel for something else and leave them there.
  7. #7 Re: want to remove guages. dont know how
    Jacksonville, Fl
    Well there's a couple reasons I want to get rid of the gauges. One, the pod is an eye sore cause its warped. Two, the background says jdm in big highlighted colors. Last reason, the boost gauge says turbo right underneath the jdm logo.
    I kinda wanna keep the boost and air/fuel. So I'm considering getting a dual gauge pod and switching out the gauges so they aren't import gauges. Then getting rid of the oil temp gauge all together
  8. #8 Re: want to remove guages. dont know how
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    replace oil temp with oil pressure
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  9. #9 Re: want to remove guages. dont know how
    Jacksonville, Fl
    I wouldn't be able to use the wiring from the oil temp for the oil pressure would I?
  1. Guages
    By shawngtp in forum Audio, Security & Visual Electronics
    Last Post: 12-31-2009, 01:14 AM
  2. Guages
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-24-2008, 11:43 AM
  3. Guages
    Last Post: 02-29-2008, 04:36 PM
