Thread: 12 Volt Remote
Results 1 to 12 of 12
mainecrab 12 Volt Remote 05-30-2008, 11:36 PM
Sabrewings Re: 12 Volt Remote 05-31-2008, 12:21 AM
SyntheticShield Re: 12 Volt Remote 05-31-2008, 07:14 AM
Iron Indian Re: 12 Volt Remote 05-31-2008, 11:51 AM
notladstyle Re: 12 Volt Remote 06-07-2008, 09:23 PM
stlmo_gtp Re: 12 Volt Remote 06-18-2008, 05:28 PM
Ninjo Re: 12 Volt Remote 06-19-2008, 02:08 PM
archemedes Re: 12 Volt Remote 06-19-2008, 10:41 PM
notladstyle Re: 12 Volt Remote 06-20-2008, 07:30 AM
archemedes Re: 12 Volt Remote 06-20-2008, 06:30 PM
  1. #1 12 Volt Remote
    GT Level Member mainecrab's Avatar
    Feb 2008
    Installing a new toy in the car, but need to know where I can tap into the twelve volt remote for it to be on only when the car is running or on. I dont have a repair manual for the car, so I guess I need to buy that before I do anything, unless anyone knows a simple way.
    Thanks,
    Mainecrab
  2. #2 Re: 12 Volt Remote
    Barksdale AFB, LA
    Could get a littlefuse add-a-circuit and tap something like the windshield circuit.
    2009 Subaru Impreza WRX STI
  3. #3 Re: 12 Volt Remote
    Oklahoma
    Yeah, add-a-circuits are wonderful things. There is a power drop behind the glove box with its own connector, but I am unsure if its a constant or switched/ignition 12v.
  4. #4 Re: 12 Volt Remote
    Moore, Oklahoma
    The power drop has 12v Switched, 12v Constant, and Ground. Its behind the glove box...
    Shawn W. Larsen
  5. #5 Re: 12 Volt Remote
    however, the power drop is ignition switched, not accessory switched... im a little late to reply you are probably already done with the project
  6. #6 Re: 12 Volt Remote
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Found on another site
    The only wire left to do before any testing was the remote power lead. This wire turns on the amplifier when it receives a 12V turn-on voltage. This is usually a much thinner wire than the power and ground connections for the amp, since it draws very little current. It's typically about 18 ga.
    I have the UP3 stereo (CD in dash) with the rear-window antenna. The presence of the rear-window antenna makes it very easy to get a turn-on voltage for this lead. The wire to tap into is the yellow lead that goes to the antenna amplifier. It turns out that the antenna amp needs the same turn-on voltage to do it's job. The bonus is that this lead is also hot when using the CD. (I cannot speak for other stereos, or for cars with the mast antenna. If you don't have the rear-window antenna, you may have to get a signal from the instrument panel fuse block)
  7. #7 Re: 12 Volt Remote
    SE Level Member Ninjo's Avatar
    Houston, TX
    you could always instal your own switch.. that what i did w/ my blazer.. just run a wire from the power lead terminal of the amp, to thw switch and the remote terminal to the other prong of the switch and there you go.. if it has an LED light you'll need to ground the switch.
  8. #8 Re: 12 Volt Remote
    Saraland Alabama
    Quote Originally Posted by Ninjo View Post
    only issue with that is you must remember to shut it off when you get out. I use my remote turn on lead from my radio (stock doesn't really have it though) with a relay
  9. #9 Re: 12 Volt Remote
    Quote Originally Posted by archemedes View Post
    did you read the thread before you posted? All stock stereos have an antenna amp remote lead regardless of whether they are equipped with the antenna amp or not.
    This IS the remote lead for the stock radios.
  10. #10 Re: 12 Volt Remote
    Saraland Alabama
    Quote Originally Posted by notladstyle View Post
    antennae is not a remote lead, turn your radio to cd and watch your antennae. I am not a fan of adding an amp to a stock radio (noise sucks, and most of those setups introduce noise) my comment was related to using the toggle switch
  11. #11 Re: 12 Volt Remote
    The antenna lead is powered on with the stock headunit even when playing CDs
    The stock headunit does not introduce noise any more than an aftermarket headunit, it is poor installation that produces noise.
  1. how to flush mount your remote bass knob and an led [*]
    By s1795so2 in forum How To Write-Ups/Tech Tips
    Last Post: 11-19-2009, 10:14 PM
  2. want to add shock sensor to existing car security/remote start
    By fst in forum General Tech Discussion
    Last Post: 01-11-2008, 06:55 PM
