Thread: A few questions
Results 1 to 3 of 3
  1. #1 A few questions
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    alright i am wanting to hook up a amp/sub to my stock head unit i have all the power ran, but was just curious on how to install the inline converter so that i can have the rca cables, do i have to bypass the stock amp ? or where is the easiest spot to tap into it ? i forgot to say that i have a 98 gtp
  2. #2 Re: A few questions
    May 2008
    Portsmouth, NH
    You shouldn't hafta bypass anything... whatever inline converter you get should have a wiring diagram, but in case you can't understand it.... most GM speaker wire coloring includes purple, purple with a stripe, white, white with a stripe, green, green with a stripe, and gray, then gray with a stripe. Obviously the colored pairs are positive and negative for each speaker. The install from start to finish is actually really really easy... bu not as easy as buying a better aftermarket deck and installing that instead, hehe =)
  3. #3 Re: A few questions
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Tap into the rear amp up under the deck if all you want is to run a sub and amp. its very easy to get to and all you would need is a 6' set of rcas.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  1. Headlight questions
    By ABINOK in forum General Tech Discussion
    Last Post: 06-21-2008, 12:25 PM
  2. mod questions
    By kingd44 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2008, 08:04 PM
  3. quick questions
    By mexico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-18-2008, 04:13 PM
  4. New guy with questions
    By chuy53511 in forum Introductions/Noob Questions
    Last Post: 02-03-2008, 07:20 AM
  5. IPW questions
    By fst in forum PCM Tuning
    Last Post: 01-11-2008, 06:44 AM
