Thread: How to hook footwell lights to dash?
Results 1 to 6 of 6
  1. #1 How to hook footwell lights to dash?
    GTP Level Member apierce1289's Avatar
    United States
    Ok im putting red LED lights in my car but i want the foot well lights to come on when its dark out. Is there a way to make them automatically come on with the dash lights? And which wires would i have to splice into? Also i understand i will need to rip the dash apart so that's fine If possible i would like them to also function as normal but if not thats ok as long as they come on at night when im driving ill be happy
    If your wondering this is the kit i bought but im only doing the dash light thing for the footwell
    http://www.diodedynamics.com/catalog...roducts_id=265
  2. #2 Re: How to hook footwell lights to dash?
    Quincy, Mass
    i had blue neons that came on with the gauges and it honestly made it hard to see at night.
    but if you still want to do it, i hooked them to the headlight switch, i believe it was the brown wire but im not sure.
    No more GP 04 Impala SS Indy:
  3. #3 Re: How to hook footwell lights to dash?
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    my friend did the same and he hooked them up to the headlight wire that lights up the radio
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  4. #4 Re: How to hook footwell lights to dash?
    Feb 2013
    Saskatoon, SK Canada
    Would you be able run it into the dimmable switch for interior lights. Thatwould be sweet . I guess you can just install a dimmer switch probably
  5. #5 Re: How to hook footwell lights to dash?
    Banned
    Jan 2013
    Colorado
    find the right wire then yes
  6. #6 Re: How to hook footwell lights to dash?
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    if you haven't already solved this, the easiest way would be to tap into the orange wire in the radio harness. I would recommend using a relay.
    02 sedan, top swap
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Dash Lights
    By stoner17971 in forum Audio, Security & Visual Electronics
    Last Post: 06-15-2009, 04:01 AM
  3. Dash lights...
    By Boosted02GTP in forum General Tech Discussion
    Last Post: 03-11-2009, 05:04 PM
  4. Dash lights go out..
    By GTPColby in forum General Tech Discussion
    Last Post: 09-11-2008, 11:35 PM
  5. Dash lights out
    By archemedes in forum General Tech Discussion
    Last Post: 01-24-2008, 01:13 PM
