Thread: Engine Bay Ignition Wire?
Results 1 to 12 of 12
  1. #1 Engine Bay Ignition Wire?
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Anyone know of an ignition on wire I can tap or how I can run my own fuse? I plan on hooking up some LED's and I want them to turn on with the car but since there on the headlights I dont want to run wires through the firewall. Any ideas?
    Infinity all around.
  2. #2 Re: Engine Bay Ignition Wire?
    Run a relay for the headlights and LED's?
  3. #3 Re: Engine Bay Ignition Wire?
    I already ran a harness for my hids but i need an ignition switched source for my leds.
  4. #4 Re: Engine Bay Ignition Wire?
    So anytime the ignition is on you want the LED's on?
  5. #5 Re: Engine Bay Ignition Wire?
    Yes sir.
  6. #6 Re: Engine Bay Ignition Wire?
    Cruise control module.......
    the brown wire should be hot in run.
    10 A fuse for the circuit.
    Wiper motor......
    Yellow wire hot in accy or run.
    pink to transmission is hot in run, 10 A.
    pink to PCM is hot in run, 10 A.
    pink to evap vent solenoid is hot in run, 10 A.
    And thats all i've got...
    Get yourself something with wiring diagrams.
    It makes life easy.
  7. #7 Re: Engine Bay Ignition Wire?
    NOw if only those wires were in the engine bay, I would be set.
  8. #8 Re: Engine Bay Ignition Wire?
    Banned
    Sioux Falls, SD
    There are many pink wires in the engine bay.
  9. #9 Re: Engine Bay Ignition Wire?
    Quote Originally Posted by chamilton89 View Post
    Cruise module is on the strut tower
    Wiper motor under the cowl, wiring runs out from cabin through firewall up to cowl area.
    Transmission is next to the engine
    PCM is either in the airbox or sitting on the driverside inner fender area.
    Evap soleniod is on the motor
    The motor is next to the trans.
    All are in the engine bay, which is why they were suggested to you.
    Personally though..I'd suggest you go to the fuse box on the passenger strut tower and find a good ign circuit, then run a relay for the led's. That way if you add more later you ensure there's no worry about popping a fuse for a critical circuit.
  10. #10 Re: Engine Bay Ignition Wire?
    Yeah, I was looking into just adding a relay as well, just using the ign control wire from the interior circuit block, I just don't wan to have to run another wire through the firewall, such a PITA. Thats why I was looking for a wire in the engine bay already to tap, then run a relay so I can draw all the power I like without worrying about blowing the circuit. Ill look into tapping the cruise control module. Shouldn't be difficult.
  11. #11 Re: Engine Bay Ignition Wire?
    but aren't you going to pull your power from the fuse box? If so..why not find an ign wire in the box to keep both your connections nice and close instead of across the engine bay?
  12. #12 Re: Engine Bay Ignition Wire?
    FrOm what I've been reading as well as been Looking at my wiring diagrams for the car, the fuse box under the hood is hot at all times. I would love to add a circuit an fuse to that panel but I want an ign switched hot. To do that I have to run a new circuit in the interior fuse block. I would do this but I hate running another wire through the firewall. There inlies my problem. Since I'm only look to draw about 400mA I don't mind pulling from any ign switched wire, just would prefer it being under the hood.
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. melting wire from ignition switch
    By Bronze in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-27-2010, 08:46 PM
  3. Where Do I Find My Key/Ignition Power Wire To Hook My Amp Up To?
    By AhtomusPrime in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2008, 12:57 PM
  4. Engine Ground to Chassis wire
    By AlmightyBirdman in forum Audio, Security & Visual Electronics
    Last Post: 06-18-2008, 07:39 AM
  5. Engine Guru's, Help Me Understand Ignition Timing
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2008, 04:28 AM
