Thread: Looking to install subs and amp.
Results 1 to 12 of 12
  1. #1 Looking to install subs and amp.
    Dec 2010
    DMV
    I've searched and learned alot from thes forums but have a quick question?
    I have a pyramid pb449x amp (older amp from other car) and a pair of magnum subwoofers. Looking to know which wires to get and fri
    Where? I know how to hook everything up just don't wanna get the wrong wires and eff something up thanks you guys!
  2. #2 Re: Looking to install subs and amp.
    Ocala, FL
    Power, ground, RCA's and a signal/remote wire.
  3. #3 Re: Looking to install subs and amp.
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    Quote Originally Posted by codyAK View Post
    this and quality audio equipment.
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  4. #4 Re: Looking to install subs and amp.
    GT Level Member jakewet28's Avatar
    Cincinnati
    Do you have a stock or aftermarket radio?
    VS Cam, SS Intercooler, Powerflow catback, SSAC headers, open cone, 180* tstat, 42.5lb injectors, 2.8 pulley, 3.29 gears, zzp pcm, all supporting mods
  5. #5 Re: Looking to install subs and amp.
    Dec 2010
    DMV
    Aftermarket radio, and it's quality to me lol. Just want a extra bump lol. And it's my first install so it should be fun.
  6. #6 Re: Looking to install subs and amp.
    Feb 2009
    Virginia
    I bet you're just fine blue
    need any help don't be afraid to ask
    11 is louder than 10!
  7. #7 Re: Looking to install subs and amp.
    Dec 2010
    DMV
    Thanks 1800COLLECT, what size wire should I use? Was looking at a cheap Walmart cables lol.
  8. #8 Re: Looking to install subs and amp.
    Cincinnati
    4 guage for power and ground and preferably 12 for speaker and doesn't matter for turn on 16 guage will work
  9. #9 Re: Looking to install subs and amp.
    Feb 2009
    Virginia
    Quote Originally Posted by jakewet28 View Post
    4awg is good because it will allow your system to grow. Use the same size or larger for any grounding. Grounding--make certain you have good surface contact and LOTS of it.
    You only need 16awg wire at best for your subs. Don't worry about getting pulled into high end wire all over the place...as long as it's copper and is well insulated so that they don't damage easily. RCA's are the same way. There isn't enough EMI present in vehicles to worry about balanced inputs and noise cancellation. Who cares about 90 degree twists and blah blah blah...just don't run it next to power wire and you're fine. Also, nickel plated is nice to prevent corrosion. That's also a very good reason to solder everything. That's really the only deterrent to quality...corrosion. Install is more important hardware. Frequent my sig links and they'll lead you to lots of information you'll probably never need
    Turn on wire can be 20awg but be careful about lengths. If you ever turn on more than one item you probably want it hooked to a relay.
    AMP KIT 2500 WATT 4 AWG POWER WIRE WIRING KIT INSTALL - eBay (item 380315502615 end time Mar-11-11 19:21:07 PST)
    That's probably as simple as it gets.
  10. #10 Re: Looking to install subs and amp.
    Dec 2010
    DMV
    Thanks guys, any tips as to installing the stuff into the car? Firewall locations? Easier routing locations?
  11. #11 Re: Looking to install subs and amp.
    Houston
    I find it easier to use the grommet on the passenger side to run the power wire through. The grommet on the driver side is down below the brake booster and I recently just ran my boost gauge vacuum line through there and it was not a good time. Once through your firewall, just continue the line under your carpet and door moldings and through your backseat to the trunk. ( just pull out the bottom portion of your backseat) Do the same for the RCA's and turn on lead on the opposite side. And youre ready to go.
  12. #12 Re: Looking to install subs and amp.
    Feb 2009
    Virginia
    check out my gpona build log for ideas
  1. got subs...but what amp?
    By coreygnar in forum Audio, Security & Visual Electronics
    Last Post: 07-30-2010, 02:43 AM
  2. Need new subs
    By robahr24 in forum Audio, Security & Visual Electronics
    Last Post: 01-04-2010, 10:52 PM
  3. DD subs in a GP
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2009, 03:10 PM
