Thread: Stereo System Thumping = Lights Dimming?
Results 1 to 20 of 40
  1. #1 Re: Stereo System Thumping = Lights Dimming?
    Donating Users zx7r4u2nv's Avatar
    butler, pa
    ^^^^^ good setup. Ya, dimming lights could be many issues but usually not enough power on supply. Caps do help but must be sized properly. My last setup has a 15 farhad capacitor called"the cap" and looked like a large amp. Also ran 2 optima yellow top batteries with a 160 amp alternator built by my local alternator shop. Power wire was a single 4/0 cable(about the size of my thumb) and ground was same size. This was for somewhere in the range of 2100 watts(subs only) in 3 mtx 225HO amps pushing 6-12" JL audio W3's. Component amps usually not much of an issue.
    Now i have stock stereo.
  2. #2 Re: Stereo System Thumping = Lights Dimming?
    Feb 2009
    Virginia
    Quote Originally Posted by zx7r4u2nv View Post
    You can only pull what the system is grounded for. If you pull more than that your voltage can bottom out...causing your lights to dim.
    11 is louder than 10!
  1. Lights and power issues / Dimming and slow
    By zeppelinrocks18 in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2012, 04:04 AM
  2. F.A.S.T. stereo system. Compromise vs. Quality
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 08-22-2010, 07:30 AM
  3. Dimming dic and stereo with out parking lights?
    By Ezequiel in forum Visual/Body Modifications
    Last Post: 08-14-2010, 02:09 PM
  4. Rough Idle and Dimming Lights
    By paulygp09 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-05-2010, 09:33 PM
  5. 2008 GP charging system lights
    By RadoZ71 in forum General Tech Discussion
    Last Post: 01-20-2009, 02:02 PM
