Thread: Stereo System Thumping = Lights Dimming?
Results 1 to 20 of 40
  1. #1 Re: Stereo System Thumping = Lights Dimming?
    Quote Originally Posted by chamilton89 View Post
    You need a capacitor to equalize the discharge on your alternator, when your bass "hits" its a huge surge on your alternator and thus lowers the overall voltage of the entire electrical system thus resulting in the dimming of the lights. In order to fix this problem you need a capacitor to equalize the voltage. The capacitor acts as a small reserve which can drain very quickly and recover its voltage slower, thus acting as a barrier between your amps high draw and the rest of the charging system. Many people in the forum will tell you capacitors will do nothing, I strongly disagree. They are a vital link between your charging system and amplifiers. Because they charge slower than they discharge, they are a require a much more "constant" demand instead of the huge surge of power demanded when your system hits. The capacitor you require will depend on how much amperage your amplifiers require. Although the capacitor will fix your "dimming" issue, it is not a fix for a system that is drawing more than your alternator will produce. If your system is >1000w RMS I would look into a HO alternator. There are so many variables that go into that decision but thats my rule of thumb for our GPs. Hope I could help!
    fixed a little but if your amp has the proper internal power supply this shouldnt be an issue.
    Cheap amps suck.
  2. #2 Re: Stereo System Thumping = Lights Dimming?
    Never Never Land
    Quote Originally Posted by csssaint12 View Post
    Caps don't do ****
    Agree
    A cap will do nothing to help. A 160A+ alternator will be the only thing. Especially if running over 500W
    Agree
    Quote Originally Posted by That Canadian Guy View Post
    might as well put some cinder blocks in there.
    Moved.
    Agree...a battery is just more draw from the alternator.
    Still won't do anything. It just means that your alternator has to keep 2 batteries charged instead of just one.
    Agree
    Cheap amps suck.
    Agree..proper wiring should rememdy most of the issue
  1. Lights and power issues / Dimming and slow
    By zeppelinrocks18 in forum Audio, Security & Visual Electronics
    Last Post: 05-07-2012, 04:04 AM
  2. F.A.S.T. stereo system. Compromise vs. Quality
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 08-22-2010, 07:30 AM
  3. Dimming dic and stereo with out parking lights?
    By Ezequiel in forum Visual/Body Modifications
    Last Post: 08-14-2010, 02:09 PM
  4. Rough Idle and Dimming Lights
    By paulygp09 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-05-2010, 09:33 PM
  5. 2008 GP charging system lights
    By RadoZ71 in forum General Tech Discussion
    Last Post: 01-20-2009, 02:02 PM
