http://www.grandprixforums.net/i-can...tion-6277.html
^^^ Follow this. I had the same problem and this took care of it.
another way is tht little hole under the steering column u can stick a screw driver in there. stick it in there and push up then it will make the key come back...i had the same problem i just put a piece of foam in there but the only problem was tht u can take the key out when the car was in any gear when the car was off. but it works.
