I want an auxiliary input in my car for an ipod. I bought a usa spec pa11-gm45 interface but I dont think my radio has the source button I need for it to work. What do you guys do?
Sorry to thread jack but I have a Sony 420-IP with an Ipod cable built in. I am not that familiar with Ipods and am planning on getting one. My question is do they all have the same port for the cable on them. I just want a simple one like the nano or something.
Oh. So basically everyone has an aftermarket head unit? My car is a limited edition so I was wanting to keep it stock for now. I might just go with a Pyle PLMD9 inline fm transmitter. I have one from a car I used to own
I threw it in the trash can because it was garbage.
The iPod that is.
seriously matt? were your audio files 320kbps? do some google searching, i know you can take apart your deck and hardwire a 3.5mm headphone jack to allow you to use it rather than your input function. i'm not entirely sure if that's accurate, but i know something of the sort is workable. if you can't find that article or don't have the know-how, go with a transmitter. usually the amount of money spent directly influences quality.
out of 5 or 6 that i have owned, this dlo was the best for sound quality, hands down.
What does bitrate have to do with it?
The thing was stuck in the eternal reboot mode.
ohhh i was under the impression you didn't like the SQ.
i've went through a couple with the reboot and dead batteries. the first gen click wheel was the worst. had that thing refurb'ed like 5 times before i upgraded a few years ago.
Just researching ipod option as well for 2000 Pontiac Grandprix with bose system single cd - seems it also lacks the aux/cd changer function. BigBadjohn & others - I am curious if you found a non-fm solution? Seems like all the forum posts with alternatives require cd changer/aux input on back of radio. Thanks!
Adapters - 1995+ GM Radio Auxiliary Input Adapter: PIE GM9-AUX (RCA)
This works in the following applications, but ONLY for radios that have the 9-pin auxiliary plug on the back AND are capable of controlling a remote CD player (single or multi). This does NOT mean it will work for you just because your radio has the 9-pin plug. For starters, your radio must have a TAPE AUX or CD AUX button OR you must already have a factory remote CD player.
i was going to buy this to listen to music with my iPhone
Griffin iTrip FM Transmitter - Apple Store (U.S.)
idk if it works or not but here tis. apple sells it and my buddy said it'd work sooo
anyone know of a deck that has at LEAST 5 lines and could support a USB HDD?
