Thread: need help with theftlock in '08 GXP
Results 1 to 7 of 7
rayl need help with theftlock in... 02-12-2011, 07:02 PM
michaelbm Re: need help with theftlock... 02-13-2011, 10:03 AM
rayl Re: need help with theftlock... 02-13-2011, 11:19 AM
michaelbm Re: need help with theftlock... 02-13-2011, 11:15 PM
rayl Re: need help with theftlock... 02-14-2011, 05:19 PM
GTP in RTP Re: need help with theftlock... 11-01-2011, 09:35 PM
Fivefingerdeathpunch Re: need help with theftlock... 11-01-2011, 09:55 PM
  1. #1 Re: need help with theftlock in '08 GXP
    USA
    thanks again michaelbm, you are a saint. That puts my mind at ease, I also thought about putting a factory navigation in when I saw used ones on the web, I'm guessing you probably had to have the VIN # changed in the unit? I couldn't find a used one locally though. I think though, adding two AUX inputs and her using her android phone for google NAV and internet/MP3 was a good trade off here is the AUX unit I bought Amazon.com: SOUNDGATE SDSGM2 Auxiliary Interface for 2003-2005 GM With Factory XM Satellite Radio: Electronics I have two other question for you this device I bought and have in hand, has a wiring harness with a male and female factory connectors that plugs in between the 12 pin connector at the back of the radio, can you possibly share what the "pinout" of this connector goes to? I have found information on the 24 pin connector but nothing on this 12 pin connector. Second question is where to get this program you mentioned on servicing this car. Thanks in advance, Ray
  2. #2 Re: need help with theftlock in '08 GXP
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I noticed the radio in my 97 GTP has theftlock printed on the front.
    Can I swap out the battery without it locking up ?
    Just bought car and not sure of history of battery.
    thanks
  3. #3 Re: need help with theftlock in '08 GXP
    it depends, sometimes it will lock, sometimes it wont, some cars are different.
    If it does, try the code 510, its a universal code I got a while back, I use it on mine and it works everytime.
  1. how do i reset the theftlock???
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-29-2008, 03:08 PM
