Thread: H.O. Alternator dims more than stock
Results 1 to 6 of 6
  1. #1 H.O. Alternator dims more than stock
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    okay i got my stereo in and my mechman 270amp alt, the problem im having is im getting considerable dimming even while driving my amp is only rated for 2600 watt rms so the alt is more then enough.
    i know it has a 10% overdrive pulley could this cause a issue with the belt being too loose and slipping under a load?
  2. #2 Re: H.O. Alternator dims more than stock
    Feb 2009
    Virginia
    grounds grounds grounds. You have terrible grounds. If you had decent grounds to begin with you would have NEVER had to "upgrade" since you have nothing that uses that extra amperage.
    11 is louder than 10!
  3. #3 Re: H.O. Alternator dims more than stock
    GTX Level Member cerick08GP's Avatar
    If the belt were slipping I’d imagine you would notice other components slipping first. Think about it, by having one under sized pulley potentially loosens the whole system. And sure a smaller pulley decreases the wrap on the alternator by a very small amount, but tons of people have made this change without issues. The belt tensioner is normally more the capable of handling one pulley change. I certainly hope you checked out the belt and tensioner condition as the HO alternator was installed.
    I would probably start by checking all your big electrical connections, and break out the old multi-meter checking for voltage drops. The fender well ground on all GPs are a POS, it is always a good place to start. Next I’d be looking at a nice battery. I’d aim for about 800CCA. And of course I have made the assumption you are running proper wire sizes to support the audio equipment.
    Good hunting.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: H.O. Alternator dims more than stock
    Feb 2009
    Virginia
    FYI...there's a guy on GPONA who has 4 runs of 0awg for his SPL setup on a stock alternator. He runs about 2.5kw I believe for his SPL setup running sine waves(WAY harder on electrical than music). He took that to world finals in his category. So it comes down to wire crimps and grounds imo.
  5. #5 Re: H.O. Alternator dims more than stock
    Jun 2010
    Beloit, WI
    I Have upgraded both the engine ground and the chassis ground all with 1/0 all ring terminals soldered.
    i agree with you to an extent about the slipping but the belt is a gatorback that was on it when i bought it a few months ago and it looks prestine. to me i think the wrong size belt was put on in the first place as the tensioner was nearly bottomed out with the stock alt on.
    obviously i cant hear i belt slip when playing music but i can get the lights to dim by revving it up so im leaning towards needed a smaller belt
  6. #6 Re: H.O. Alternator dims more than stock
    Feb 2009
    Virginia
    You could have an issue with the belt slipping but what about your RPM's? When I had problems with my EGR, lights didn't dim until RPM's started dipping below ~750. Maybe that'll point you in the right direction.
    Also, good deal with the solder but my next question will be about surface area. How much contact are they actually making with the ground locations?
  1. HO Alternator
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2009, 08:48 PM
  2. alternator
    By Slueth66 in forum General Tech Discussion
    Last Post: 01-29-2009, 10:05 AM
  3. is it my alternator?
    By boosting98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2009, 05:38 PM
  4. 2000 GTP stock alternator?
    By MysticStyl3z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2008, 11:39 PM
