Thread: ABS Traction Control Cruise issues
Results 1 to 7 of 7
  1. #1 ABS Traction Control Cruise issues
    West Palm Beach, Florida
    my girlfriend has a 98 gtp and her abs lights and all that are on and her cruise control doesnt work. I plugged it into our scan tool at school and noticed her right front speed sensor was always at 3mph i believe. Her wheel bearing was going bad anyways so i replaced it (sensors inside the hub) but the lights are still on and her cruise doesnt work. i noticed there was a like 2 foot section of wiring that runs up the inside of the engine bay, so i was going to check continuity of those ...if that doesnt work any other ideas?
  2. #2 Re: ABS Traction Control Cruise issues
    SE Level Member kentpappy's Avatar
    Nebraska
    Speed sensor would light up the ABS. Did you delete the code after you replaced it? Cruise could be a number of things.
    2000 ZX12r (Big bore kit, Cam, 6" Extension )
    1999 Escort ZX2 (DD)
  3. #3 Re: ABS Traction Control Cruise issues
    but the ABS and traction control and cruise control is all wired together seems like if anything with the abs doesnt work none of themw ill work
  4. #4 Re: ABS Traction Control Cruise issues
    SE Level Member Phantom's Avatar
    Independence KY
    Check the tail lights and make sure one is not loose.
  5. #5 Re: ABS Traction Control Cruise issues
    Cruise is independent of the abs/traction. Cruise is based off the VSS sensor in the transmission.
    Have you checked the cable at the throttle body to ensure it's connected and not broken from prior work on the car? Or does it not try to engage at all?
  6. #6 Re: ABS Traction Control Cruise issues
    Quote Originally Posted by Phantom View Post
    what would that have to do with this?
  7. #7 Re: ABS Traction Control Cruise issues
    doesnt try to engage at all but obviously the VSS sensor in the trans is fine because the speedometer is fine
  1. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  2. traction control?
    By bensett004 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-27-2009, 08:56 PM
  3. Traction Control Issues
    By ssm90GT in forum General Tech Discussion
    Last Post: 09-02-2009, 11:31 PM
  4. Traction Control
    By tynev7 in forum General Tech Discussion
    Last Post: 08-18-2009, 10:55 PM
  5. abs traction control issues
    By morsecode in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2009, 01:39 PM
