Thread: Want to replace stock bose system
Results 1 to 9 of 9
Musclecarguy Want to replace stock bose... 01-19-2011, 10:50 PM
matt5112 Re: Want to replace stock... 01-20-2011, 12:02 AM
FoSHO99 Re: Want to replace stock... 01-20-2011, 12:21 AM
d8teen Re: Want to replace stock... 12-08-2011, 12:57 AM
Musclecarguy Re: Want to replace stock... 12-08-2011, 01:34 AM
d8teen Re: Want to replace stock... 12-09-2011, 01:49 AM
Musclecarguy Re: Want to replace stock... 12-09-2011, 08:19 AM
d8teen Re: Want to replace stock... 12-10-2011, 12:25 AM
Musclecarguy Re: Want to replace stock... 12-10-2011, 12:34 AM
  1. #1 Want to replace stock bose system
    SE Level Member Musclecarguy's Avatar
    London
    My little bro has a bose system in his grand prix. he wants to replace all of the speakers and the HU. How do you bypass the stock bose amp? Ive wired a lot of stereo systems before but none of them had a bose system previously installed. Do i have to run new wires for all of the speakers in the car? Also ive heard of a module that allows you to keep using the steering wheel controls. does anyone know where you can get them and what exactly they are called? He has a 2002 GTP 40th Anniversary and i believe he has onstar as well. Thanks
    2002 Grand Prix GT (Push button start system, LED Tail lights, Flowmasters with Oversized dual round SS Tip, K&N Air Filter, Custom Projector Headlights with LED strip and HIDs, HID Fogs, 18" Chrome rims with Continental Extreme Contact DW summer tires, and a loud sound system) DD
  2. #2 Re: Want to replace stock bose system
    I'd suggest leaving the bose amp in the system unless you want to add your own aftermarket amp as well.
  3. #3 Re: Want to replace stock bose system
    Jan 1970
    Maquoketa, Iowa
    I just took all the bose out and ran new speakers and wires to the headunit. The steering wheel controls interface is a pac-something... may have to find out which one is compatible but it is similar, if not this: PAC SWI-X Steering wheel control interface — use your factory steering wheel controls with an aftermarket stereo at Crutchfield.com
  4. #4 Re: Want to replace stock bose system
    SE Level Member d8teen's Avatar
    Jul 2010
    Fl-Hollywood
    FoSHO99
    How hard was it to rewire the whole thing? did you take door panels out and everything?
  5. #5 Re: Want to replace stock bose system
    London
    Yes we took the door panels off. Only way to change speakers. We also had to take back seat out to get at rear speakers. And then all the trim peices in between. Wasn't too hard but this ilwasnt my first time running wires through a car and taking trim and stuff off. So if you have time and are a hands on person you can give it a shot. If not I would find somebody that can. Took me a whole Saturday to replace all speakers, all new wire and a deck and subs.
  6. #6 Re: Want to replace stock bose system
    Jul 2010
    Fl-Hollywood
    Thanks for your reply man, I would of course do it myself, have changed rear speakers and all. Probably its the best way to do is to completely rewire the whole thing.
    Now they dont sound any good, amp blown i guess. Previously have done subwoofer wiring. But dont look forward probably to take the whole thing apart again, seats and all. OK here few questions, did you run it directly from head unit not amp? And did you put 6.5 in the door or stock size?What gauge did you use? for rear probably best way is to do amp i guess since there 2 speakers. loud and lows.
  7. #7 Re: Want to replace stock bose system
    London
    Depending on the speakers you put in you can usually get away with running the power from the deck for speaker power unless you want it really loud. We used all stock size speakers otherwise you will have fitment issues. I don't remember the gauge just look online and usually you can find what size you need. Check what power the speakers are and how much you plan on giving them. and there is actually 6 speakers in these cars. 2 in front(one in each door) and 4 in the rear (2 per side up by window) if your gonna run amp get a good 4 channel for the speakers. And run the rear sets together. Just join each side together. So 4 inputs just like normal only with 2 speakers wired together per side at the rear.
    Here is a chart I pulled off the Internet for speaker wire. If my memory serves me correctly I think we used 14awg
    Wire Size 2 ohm load 4 ohm load 6 ohm load 8 ohm load
    22 AWG 3 feet max. 6 feet max 9 feet max 12 feet max
    20 AWG 5 feet max 10 feet max. 15 feet max. 20 feet max
    18 AWG 8 feet max 15 feet max 23 feet max 30 feet max
    16 AWG 12 feet max 25 feet max 37 feet max 50 feet max
    14 AWG 20 feet max 40 feet max ******* *******
    12 AWG 31 feet max ******* ******* *******
    10 AWG 50 feet max ******* ******* *******
  8. #8 Re: Want to replace stock bose system
    Jul 2010
    Fl-Hollywood
    Thanks for reply. Well there also tweeters in the front so 4 + 4. Thinking going to do it some time soon, when i sell my other car.
  9. #9 Re: Want to replace stock bose system
    London
    Well usually the tweeters are wired along with the front speakers. Connected with a box or sometimes just right to the speaker itself.
  1. Bose sound system
    By mikesarebetter in forum Audio, Security & Visual Electronics
    Last Post: 12-03-2010, 11:08 PM
  2. bose sound system issues
    By 99gtpsupercharged in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2010, 08:19 AM
  3. BOSE System Swap from Stock
    By dbextreme in forum Audio, Security & Visual Electronics
    Last Post: 12-08-2009, 06:56 PM
  4. Factory Amp In A 00 GP with Bose System
    By quickgt in forum Audio, Security & Visual Electronics
    Last Post: 05-25-2009, 11:19 AM
  5. How Can I Switch Out My BOSE System 4 My New Stuff
    By thagizzle213 in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2009, 11:11 AM
