Thread: Rear Deck Speaker Installation
Results 1 to 20 of 24
  1. #1 Rear Deck Speaker Installation
    Edmonton AB
    Has anyone does this on the 04+ Grand Prix? I heard it's a pain in the ass and I don't know if the labor would seriously account for it being that.
    I was quote 287.60 for parts and labor for the one speaker. I think that's a bit much when the speaker itself is only 129.
    A step by step or maybe a walk through of how to do it would be nice. I have the monsoon stereo system.
    Thanks in advance,
    -Garrett
  2. #2 Re: Rear Deck Speaker Installation
    Pennsylvania
    I'm in the process of making a tutorial for this. It probably takes about 1.5 hours to change the speakers if you're handy with a wrench. It's a total pain in the ass, but there's nothing difficult - just tedium.
    My advice: Do not bother just to replace them with the stock speakers - and definitely do two at a time. This is only worthwhile if you upgrade. (I got used stockers on the cheap from Morad and it still wasn't worth the effort to me.)
    Also, at 1.5 hours, that guy is asking for $100/hour. That install had better come with a happy ending.
    And you can definitely find a better speaker at $129.
    Quick and Dirty:
    1. There's two T-shaped handles under each seat where your balls would sit. Pull those. Harder. Your rear seat will pop out. Remove it.
    **Pro Tip: You'll find approximately $0.82 and an entire box of crackers. Keep the money, the crackers can be discarded as they are a 30,000 mile part and have been dragging down your 1/4 mile times.
    2. There's a 15mm? bolt on the door-side edge of the hinge on both seat panels. You'll have to squeeze it past some cushion. Jiggle your panels out.
    3. The bottom of the seat frame is held down with three 18mm? nuts and two 18mm? bolts. The bolts will require your Man Hand for removal.
    4. The top of the frame is held on by four 10mm bolts. Piece of cake.
    5. Remove the seat belts from the bottom of the frame with some serious jiggling. Might help to use a flat head screwdriver or loud yelling.
    6. Pop out the frame, being careful not to break the plastic at the top.
    7. Fold all the seatbelts through the slits in the upper desk tso that they lay behind it.
    8. The carpet-coated cardboard deck is held in by two big plastic railroad spikes right under the seatbelt holes you need to pull out. Yell at them, too.
    9. Carefully remove the deck. Try not to crack your speaker grills - they're ironically fragile. Also, don't lean on the compass thing in front of your amp.
    **Pro Tip: Have a vacuum cleaner handy for the three hundred dead bees you find.
    10. Your speakers are held in by two plastic tabs each. You can figure that out for yourself if you got this far.
    11. Use a flat head screwdriver, roofing nail, or prison shank to un-clip the speaker wires from the speaker.
    12. Swap speakers.
    13. *****TEST SPEAKERS BEFORE RE-ASSEMBLY OF SEATS******
    14. Re-assemble seats.
  3. #3 Re: Rear Deck Speaker Installation
    Edmonton AB
    Thank you VERY MUCH for this. I will document everything myself as well to help out others.
    I laughed so hard when I read this... My car only has 46,000km on it so I don't think I'll find too many bees and coinage.
    Should I take off the negative terminal in the car or no?
    You're saying I should do this myself then, correct? Do you have pictures?
  4. #4 Re: Rear Deck Speaker Installation
    Pennsylvania
    Quote Originally Posted by garreTT View Post
    It doesn't hurt to unhook the battery. By the time I got the deck off, my amp had shut off, so I didn't worry about it.
    I'd say to do it yourself. If your time is that valuable, I'd say find someone to do it for $30. Or beer.
  5. #5 Re: Rear Deck Speaker Installation
    SE Level Member joelnv02GTP's Avatar
    alberta, canada
    sorry, i have an 02 so id b no help but im like half hour away from ya lol if ya had the same yr as mine, but the rear deck speakers may b same removal procedure
  6. #6 Re: Rear Deck Speaker Installation
    Edmonton AB
    Quote Originally Posted by joelnv02GTP View Post
    Where are you here in Alberta? I'm on the north side of Edmonton.
    If you'd like to come over I'm sure I wouldn't mind some help.
  7. #7 Re: Rear Deck Speaker Installation
    alberta, canada
    im in spruce grove myself
  8. #8 Re: Rear Deck Speaker Installation
    Edmonton AB
    I wouldn't want you to drive out here with the roads the way they are.... Yellowhead is stupid at this time of year anyway.
    My time is seriously not that valuable and I'm sure that I could accomplish it myself.
    Another question, you replaced the whole speaker system correct?
  9. #9 Re: Rear Deck Speaker Installation
    Pennsylvania
    Just the 6x9 deck speakers.
  10. #10 Re: Rear Deck Speaker Installation
    Edmonton AB
    Quote Originally Posted by SlowNA06 View Post
    Did you replace with the same stock 6x9s? Is the wiring stupid proof plug and play?
    - Joel, we'll have to get together some other time haha I would just feel bad if anything was to happen! It's just how I am .
  11. #11 Re: Rear Deck Speaker Installation
    Pennsylvania
    Yeah, I used stock ones. Plug comes out, plug goes in. Piece of cake.
  12. #12 Re: Rear Deck Speaker Installation
    alberta, canada
    lol drive to city evryday for work in my car i replaced everything front to back
  13. #13 Re: Rear Deck Speaker Installation
    alberta, canada
    ya no prob man maybe oraganize a meet on a sat night or sumpin
  14. #14 Re: Rear Deck Speaker Installation
    alberta, canada
    sendin pm
  15. #15 Re: Rear Deck Speaker Installation
    GT Level Member dengnath's Avatar
    is it a different process if you have the seats that fold down?
  16. #16 Re: Rear Deck Speaker Installation
    Pennsylvania
    Quote Originally Posted by dengnath View Post
    All seats fold down. This is the one-and-only process.
  17. #17 Re: Rear Deck Speaker Installation
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    I am trying to do this today with my 2006 GT. I have fold down seats and am stuck. I had to remove the seats when I did ky 2000 GTP, but this is a different setup. I have the seats down and the 10mm bolts holding some bracket like thing that goes the whole width of the back seat. This seems to have also allowed the rear deck to be no longer attached, but that bracket thing is in the way. It is attached to the rear seat "ends" that don't fold down (the outer 6" or so) and I can't seem to be able to figure out how to get them to let go. Ugh....
    Currently driving a 2006 Grand Prix GT - Stock
    2000 GTP was killed by 16 year old - Nov 20, 2010 - It only had 74,000 miles, a ZZP 3" Catted Downpipe, ZZP SS PLOG, FWI, 180* T-Stat, Flipped Dog Bones, GMPP Sway Bars, G2 painted Rotors and Calipers, HUMount, and was Dexcool free!
  18. #18 Re: Rear Deck Speaker Installation
    Apr 2008
    Marion, Iowa
    I should note that I am going to examine the steps at the top and find the obvious steps I have missed.
  19. #19 Re: Rear Deck Speaker Installation
    Apr 2008
    Marion, Iowa
    And just like that I am in business. Remove bottom of seat. Remove 18mm bolts and nuts (yes the bolts are snug due to locktite), remove 10mm bolts holding on the top of the seat back, pop off rear a pillar covers, pop out the two practice clips on each end if the rear deck (they look Luke plastic circles for those that have never seen them before), remove the rear deck lid (obviously the seat belts get pulled through)... now to remove the speakers, replace and reassemble....
  20. #20 Re: Rear Deck Speaker Installation
    Pennsylvania
    Quote Originally Posted by nickbuol View Post
    ...pop off rear a pillar covers...
    Unnecessary if you don't mind squeezing the deck a little (which does not hurt anything).
    ...pop out the two practice clips on each end if the rear deck...
    The what?
  1. Rear Deck Speaker Grilles
    By SlowNA06 in forum Audio, Security & Visual Electronics
    Last Post: 05-25-2010, 12:18 PM
  2. New Rear Deck Speaker Grilles Needed For 2002 Grand Prix GT
    By LoveMyGPGT in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2010, 02:32 PM
  3. Help with deck, amp, and sub installation
    By pilotim69 in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 11:52 PM
  4. deck installation question??
    By reallyfast1 in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 07:40 AM
  5. Speaker Installation??
    By ssm90GT in forum Audio, Security & Visual Electronics
    Last Post: 10-06-2008, 08:16 PM
