While that is never ideal, and is most of the time conidered a no-no. It is an acceptable location.
You still have these pics? I don't see them in the post you started about showing the audio.
Edit: Nevermind... I found them. I've always heard it was best to keep the ground under 8 to 12 inches... what would you say is max length?
Also, what do you use to make your raised lettering? I may enlist you for a little project I've got going for my 05 :)
i was told the max length was like 18 inches.
yeah 20 is the most I have ever personally gone, and I really didn't want to do that much but had to, it did not cause any problems. As long as it is a good ground it ill be fine that long, But I would suggest around 10-12" for length on ground, that way you can move it around if you get some noise and troubleshoot it a lil' easier. Mine is a little long, I just used the ground wire out of a capacitor kit and they only give you 20" in that kit and I trimmed it so prolly 14" or so.
The raised lettering is easy, I am going to post a how to real soon. So I will let you know when I get that posted up. It is so easy, once you see how to do it, you will be like wth? haha.
